ᐅ How can IKEA Hemnes furniture be used in rental apartments?
Created on: 25 Feb 2023 18:03
waleedbi
waleedbi
25 Feb 2023 18:03
Hello everyone, I will soon be moving into a new rental apartment and am considering using IKEA Hemnes furniture. I find the combination of classic design and good craftsmanship appealing, but I have concerns because rental apartments often have specific requirements, such as not being allowed or wanting to secure furniture permanently to the walls to avoid damage.
My question is: How can Hemnes furniture, like cabinets, dressers, or beds, be used optimally in rental apartments without making long-term changes to the living space? Are there any tips for setting up or combining the furniture so that it is stable without drilling into walls? And what about flexibility if a move is planned—are the Hemnes pieces suitable for this, meaning easy to disassemble and reassemble?
I look forward to your experiences and recommendations, especially if anyone has used similar furniture in a rental apartment before.
gasidney
25 Feb 2023 18:47
The Hemnes series is relatively sturdy and ideal for rental apartments because it can be used without screws in the wall. Simply place furniture with floor protectors underneath to protect the flooring. For stability, it helps to position heavier items at the bottom and avoid overloading the furniture. They are easy to disassemble and reassemble when moving.
Domau0
26 Feb 2023 09:14
To make the most of Hemnes furniture in rental apartments, a strategic approach is recommended. First, it is important to have a clear understanding of the floor plan and lighting conditions to arrange the furniture appropriately.
Wardrobes and dressers such as those in the Hemnes series are generally sturdy, but it is preferable to secure them to the wall for maximum safety (e.g., to prevent tipping). Since this is often not possible or desired in rental apartments, I recommend the following alternatives:
- Use furniture wedges or special floor levelers to compensate for uneven surfaces and improve stability.
- Add non-slip felt or rubber pads under the feet to protect the floor and prevent slipping.
- Always store heavy items at the bottom, as mentioned before, which significantly stabilizes the piece of furniture.
Regarding moving: Hemnes furniture is mostly made of solid wood with finger joint connections. These are fairly robust but may require minor adjustments with frequent assembly and disassembly. Disassembly is quite feasible, but it should be done systematically:
- Mark screws
- Label individual parts
You should also keep in mind that repeated disassembly can cause small joints to become slightly looser. To compensate, you can apply a small amount of wood glue sparingly or insert small wooden dowels if threads become deformed.
I’m also curious whether you intend to use Hemnes specifically for bedroom or storage furniture and what room size is available, as this significantly affects the planning.
pikin
26 Feb 2023 12:26
The question of how to use IKEA Hemnes furniture in rental apartments requires a nuanced answer. Hemnes furniture is characterized by the following features:
- Solid pine wood, which offers durability and ease of repair.
- A design that is rather timeless and fits well with various interior styles.
For use in rental apartments, the following aspects are particularly relevant:
- Fixing: In most rental apartments, permanent wall mounting is not desirable. Although Hemnes furniture comes with wall fasteners, it is also stable enough without installation if placed correctly. However, large dressers, such as the 8-drawer dresser, can be prone to tipping if heavily loaded.
- Solution: I recommend placing heavy furniture in corner areas to ensure stability through wall contact. Alternatively, anti-tip devices that do not require drilling (e.g., tension straps between floor and ceiling) can be used.
- Surface protection: To protect the floor, felt pads on the feet are essential, especially in rental apartments with delicate parquet or laminate flooring.
- Mobility: Hemnes furniture can be easily disassembled with basic tools, which makes moving easier. Nevertheless, frequent assembly and disassembly are not ideal for the wood.
- Space-saving use: In the area of wardrobes or shelves, flexible storage space can be created through combinations, e.g., with Hemnes shelves and dressers, without major structural changes.
By the way: Furniture should not be overloaded to avoid warping or instability. A quick question: Which specific pieces from the Hemnes series are you considering?
Domau0 schrieb:
I would also be interested to know whether you plan to use Hemnes specifically for bedroom or storage furniture and what room size is available, as that significantly affects the planning.
daalessio
27 Feb 2023 08:51
In addition to the already very good answers, I would like to add three concise tips that are especially important when using Hemnes furniture in rental apartments:
- Modular combinations: Use the different elements of the series flexibly to adapt them to your space. For example, dressers and shelves can be stacked if they are securely connected to save space.
- Moisture protection: Especially in older rental apartments, humidity can sometimes be higher. Well-seasoned solid wood furniture like Hemnes should still be regularly ventilated and not placed directly against exterior walls to prevent warping.
- Flexible wall mounting without drilling: There are solutions available on the market (e.g., clamp holder systems) that stabilize furniture against tipping without damaging walls. These are highly recommended if there are children in the household or if you want to be extra cautious.
In summary, Hemnes furniture, due to its solid wood quality and modular construction, is very suitable for rental apartments, as long as you pay attention to stability and floor protection when setting it up. This makes them both functional and easy to move.
pikin schrieb:
Which specific furniture pieces from the Hemnes series are you considering?
Maybe a concrete list of your plans would be helpful here.
