ᐅ How can IKEA Hemnes furniture be disposed of sustainably or upcycled?
Created on: 18 Aug 2020 19:23
peluana
I have a specific question about sustainable handling of IKEA Hemnes furniture, especially regarding the most environmentally friendly ways to dispose of or creatively upcycle it. Since Hemnes furniture is mainly made of solid wood and is generally quite sturdy, I would like to know what suitable options are available to sustainably recycle or reuse these pieces at the end of their life instead of simply discarding them.
I am particularly interested in aspects such as:
- What is the best way to separate the materials before disposal?
- Can some parts, like handles, drawer slides, etc., be reused separately?
- Are there proven methods for treating the wood or recycling it in other ways?
- Which local or regional options (e.g., recycling centers, upcycling workshops, donations) are recommended?
I look forward to your tips, including advice on common issues to avoid or creative projects that work well with Hemnes furniture.
Thank you in advance!
To thoroughly address the topic of recycling and upcycling Hemnes furniture, here is a detailed process description that works for me:
1. Completely disassemble: Carefully remove screws, nails, metal, and plastic parts. You can take the metal components to scrap collection; plastic parts, if recyclable, should go into the appropriate recycling bin.
2. Check the wood condition: The wood in the Hemnes series is often not dried under industrial conditions, so it is worth carefully inspecting for cracks or insect damage before reusing.
3. Sanding: Depending on the intended use, sand the wood with grit 120–180. It is important not to inhale sanding dust and to work outside if possible.
4. Surface treatment: For an eco-friendly finish, use natural oils (e.g., linseed oil) that are breathable and protect the wood. Avoid solvent-based varnishes that are harmful.
5. New construction projects: Often adjust measurements—the standard Hemnes panels are not sized to full lengths, so it can help to build extensions or supporting frames yourself.
In conclusion: If you know the exact intended use, I would be happy to offer individual advice on which tools and products are best suited.
Tause schrieb:
I wonder if using new products like stain might compromise sustainability. That is a valid concern! In my experience, it largely depends on the type of stain – natural water-based stains or earth pigment stains are significantly more sustainable and less harmful to health than chemical stains or varnishes.
Regarding surface finishes:
- The original surface sealant on IKEA Hemnes is usually water-based and fairly environmentally friendly.
- If sanding the wood, it’s best to vacuum the dust or ideally do it outside, as already mentioned.
TEBILO schrieb:
Depending on the intended use, you can sand the wood with a grit of 120-180. Also important: Excessive sanding can unnecessarily weaken the wood, so proceed with care.
For sustainable upcycling, the general rule is: minimize material treatment to keep the ecological footprint low.
