ᐅ What repair tips are available for Ikea Hemnes drawers?
Created on: 25 Jun 2020 08:17
barron
Hello everyone, I have an issue with my Ikea Hemnes drawer chest where some drawers are difficult to pull out and sometimes get stuck. I suspect that the drawer slides or runners are no longer working properly. Therefore, my question to the community is: What repair tips are there for Ikea Hemnes drawers to restore smooth operation? Are there proven methods to fix running problems, or parts that can be easily replaced? I look forward to useful advice and practical experiences!
barron
26 Jun 2020 08:33
kulau schrieb:
A lubricating but wax-based product like paraffin or a special furniture wax provides better sliding properties. Important: Do not lubricate with oil,
Thanks for the tip! Could you briefly explain why oil is unsuitable? I would have assumed that something like oil, similar to WD-40, might help. Also, which replacement parts are compatible if I need to change the rails? Are there standard dimensions for the Hemnes wardrobe?
kulau
26 Jun 2020 10:11
barron schrieb:
Could you briefly explain why oil is not suitable?
Especially for wood and plastic guides, oil attracts dust and fibers, which over time leads to even rougher sliding tracks. Grease or wax creates a dry, lubricating film that repels dirt more effectively.
Regarding spare parts: Unfortunately, Ikea does not offer individual drawer slides for Hemnes as replacement parts—only complete drawer units. Many people use universal telescopic drawer slides with full extension, which can be found at hardware stores. These are usually available in lengths of 30, 40, or 50 cm (12, 16, or 20 inches). It is important to measure the slides accurately and ensure they fit the cabinet’s internal dimensions. Minor adjustments to the wood may require some basic woodworking skills.
Ritaba
26 Jun 2020 12:47
My experience: Hemnes drawers often work better when the screws on the runners are not tightened too much. This keeps the guides a bit flexible and reduces sticking.
PIERCE
27 Jun 2020 07:50
I can add that the drawer depths in Hemnes can vary. Therefore, also check if the drawer bottoms lie flat, otherwise the ease of pulling them out may be affected. Sometimes, placing a piece of felt-lined mat under the bottom helps.
SUPE2
27 Jun 2020 09:22
Occasionally, fine wood dust that accumulates in the sliding tracks has caused issues for me. Simply sweeping it out and vacuuming with a narrow nozzle attachment often leads to significant improvements.
barron
27 Jun 2020 10:11
Dirkmin schrieb:
It is more common that the drawers swell due to moisture or that wood shrinkage causes misalignment.
I hadn’t considered that at all. I live in an older house with relatively high humidity levels during winter. So it could be that the wood’s expansion and contraction is affecting how the drawers slide. How can this be resolved without completely replacing the drawers? Are there sealants or other solutions available?
