I am currently exploring how to best adapt the IKEA Hemnes furniture range for a home office setup. Specifically, I am interested in how to modify or supplement the desk, dressers, and shelves to meet ergonomic requirements, provide sufficient storage space, and allow flexible adjustments for changing work needs. I am also curious about which functional additions through extra components would be useful without losing the distinctive Hemnes style or overcrowding the room. Perhaps someone has practical experience or creative ideas on how to optimize this range for professional work in a private space. What modifications, alterations, or accessories would you recommend to turn Hemnes into an efficient and comfortable home office environment? Thank you in advance for your well-informed suggestions.
When adapting the IKEA Hemnes system for a home office, the following aspects should be considered:
- Ergonomics: Raise the desk using separate risers or height-adjustable table legs to prevent back issues.
- Storage: Add extra dressers or units with drawers to organize work materials, sized appropriately to maintain the Hemnes design.
- Cable Management: Use cable channels or integrated solutions since Hemnes was not originally designed for electronic home office equipment.
- Workspace Lighting: Add suitable desk lamps that ideally complement the wood design.
- Modularity: Use the shelving systems as room dividers or for flexible storage options.
A practical tip is to apply self-adhesive felt pads on drawer fronts to reduce noise and create a pleasant working environment. For optimal ergonomics, selecting a separate ergonomic office chair is essential, as Hemnes does not include an integrated seating solution.
Brief and to the point: raise the table using leg extenders. Use boxes and organizers to keep the Hemnes drawers tidy. Add an LED desk lamp that takes up little space. Hide cables with clips or channels on the back. This will instantly make your home office more functional.
hauklo schrieb:
When modifying the IKEA Hemnes system for a home office, the following aspects should be considered:Interesting approach, but I wonder if the suggested modifications are truly sufficient to adapt the Hemnes series to the requirements of a modern home office. For example, the lack of cable management in the Hemnes desks is a serious issue. Simply retrofitting cable channels addresses the problem only partially and often appears pragmatic and somewhat unrefined.
islaron schrieb:
Add an LED desk lamp that takes up little space.That makes sense, but I believe it is more important to integrate a lighting solution from the start, such as shelves with built-in lights, to ensure optimal illumination.
Furthermore, I question whether simply adjusting the furniture pieces is enough, or if it would be better to look for additional products, like height-adjustable desk risers or sit-stand solutions, to compensate for the rigidity of the Hemnes furniture system. The rigid furniture design could particularly hinder ergonomic use.
I would be interested to know if anyone has practical experience with such additions that make the Hemnes desk more “flexible.” Perhaps modifications are also possible by combining the furniture with external elements?
