ᐅ What is the best way to protect Ikea BRIMNES furniture during a move?
Created on: 6 Nov 2022 14:07
dabo32
dabo32
6 Nov 2022 14:07
I am about to move and own several Ikea Brimnes furniture pieces, mainly cabinets and dressers. Since these items are generally made from relatively lightweight materials and can have delicate surfaces, I am concerned about how to best protect them from scratches, dents, or other damage.
My question for the community is: What specific measures, materials, or techniques have you used to protect your BRIMNES furniture optimally during a move? I am especially interested in tips on preparation, proper packing, secure transportation, and any additional protective solutions.
It would be great if you could also share experiences related to the particular characteristics of BRIMNES furniture—such as surface types, fastenings, or special features that should definitely be kept in mind.
Thank you in advance for your support!
Timmyse36
6 Nov 2022 14:45
Hello dabo32,
I completely understand why you’re concerned. A year ago, I also moved my BRIMNES dressers and was really nervous about the plexiglass fronts and the light-colored surfaces.
What helped me a lot was taking the furniture completely apart – removing shelves and drawers, taking off the doors, and wrapping everything in blankets or stretch wrap. Especially the drawers, I transported separately to prevent sagging or loosening during the move.
I also wrapped everything in bubble wrap and added edge protectors (available for furniture) to safeguard the corners.
Of course, this requires some effort, but since then I haven’t had any scratches or damage.
Don’t stress, you can do it!
Josefane
6 Nov 2022 15:12
A question in advance: Is it advisable to completely disassemble the BRIMNES furniture, considering that some of the connections use Ikea’s special flat-head screw system, which is not designed for frequent assembly and disassembly?
I ask because theoretically, repeatedly loosening and tightening the screws can affect the stability and the threads of the furniture.
This means that, on one hand, disassembling protects the individual parts better, but on the other hand, it may create potential weak points for breakage or loose connections.
Does anyone have reliable experience or detailed recommendations on this?
daalessio
6 Nov 2022 15:48
Josefane schrieb:
Is it advisable to completely disassemble the BRIMNES furniture, considering that some of the connections with Ikea's special flat-head screw system are not designed for frequent assembly and disassembly?
Fundamentally, Josefane has raised an important point. The BRIMNES system uses connection fittings that can indeed wear out with frequent disassembly.
If the move is not too far and the furniture is still stable when assembled, I recommend transporting it mostly intact. It should be protected with blankets, stretch wrap, and padding to absorb shocks.
However, if the transport is done in several stages or stairs are narrow, a controlled partial disassembly makes sense — in this case, it is advisable to professionally replace any damaged fittings before reassembling.
To protect the surfaces, special furniture covers or stretch wrap are suitable to prevent scratches. Additionally, sensitive fronts and edges should be padded separately.
Taubi
6 Nov 2022 16:03
Important when protecting furniture:
- Remove drawers and doors
- Cover edges with foam or edge protectors
- Wrap furniture with blankets or bubble wrap
- Avoid pressing too hard to prevent surface deformation
It is best to secure furniture on a moving trolley so that it needs to be moved less.
Jeffon
6 Nov 2022 16:37
From a technical perspective, I recommend the following approach for optimal protection of Ikea BRIMNES furniture during a move:
- Document pre-assembly: Take photos of the joints and layout to ensure safe reassembly later.
- Partial disassembly: Remove doors and drawers to prevent damage to the delicate hinges and slides. Pack furniture legs and loose parts separately.
- Padding: Use moving blankets to protect surfaces and additionally apply edge protectors on corners and edges.
- Packaging: Use bubble wrap, but not directly on surfaces, as adhesive tapes can leave marks. Instead, wrap the furniture with protective blankets.
- Transport: Secure the furniture vertically and place a layer of anti-slip mats underneath to prevent shifting during transit.
- Screws and small parts: Collect in labeled bags.
This method minimizes damage without unnecessarily stressing the connecting mechanisms.
