ᐅ How can I use Ikea Pax wardrobes to create additional storage space in the basement?
Created on: 15 Jan 2022 09:38
NemauHello everyone,
I am considering whether and how to use the Ikea Pax wardrobe system efficiently for additional storage space in the basement. My basement is dry but unfortunately somewhat lower than usual living spaces (about 2.10 m (7 ft) ceiling height). The idea is to creatively use existing Pax units or frames to create order and make the best use of the space—especially for boxes, tools, seasonal items, and smaller household objects.
Since the Pax system is primarily designed for bedrooms, I wonder how durable these wardrobe systems really are in a basement, whether remodeling is worthwhile, or if adjustments to the lower ceiling height are necessary. How have you used Pax in basements or similar storage areas, and what should I especially consider regarding material moisture, stability, and organization?
I would appreciate tips on planning, clever modifications, suitable accessories, and experiences—including ideas on how to adjust the interior layout or appearance so that it fits the day-to-day use in the basement.
Thank you!
Thank you!
Leonardteo15 Jan 2022 10:57Hello Nemau,
your question is very relevant because using Ikea Pax in a basement can be quite practical if certain conditions are considered.
First, you should ensure that the basement environment is truly dry, as the particle boards used in Pax are not very moisture-resistant and could swell or get damaged if humidity is high. A basic treatment with a water repellent or placing the units on plastic feet to avoid direct floor contact can help.
Regarding the low ceiling height, it is advisable to shorten the height of the outer frame parts accordingly or use combinations with lower-height modules. Ikea also offers half-height Pax units that might fit better.
For interior organization, adjustable shelves, drawers, and baskets are very useful. Especially in the basement, it makes sense to use sturdy, possibly perforated plastic boxes to help prevent moisture accumulation.
Finally, you should assemble the units securely, as basement floors are often uneven. You can compensate for unevenness using self-adhesive felt pads or adjustable feet.
In summary: create clearance from the floor, apply moisture-resistant measures, and adjust the height. This way, nothing stands in the way of using Pax effectively in the basement.
Hello Nemau,
I would like to add to the previous post and mention some additional points you should consider if you want to use Pax wardrobe units in the basement.
- Material: Particleboard is susceptible to moisture and temperature fluctuations. Therefore, it is important to keep the basement humidity consistently below 60%. Ventilation or a dehumidifier is recommended.
- Stability: Since basement floors are often not perfectly level, you should definitely check the stability of the substrate before installation and secure the units to the wall with anti-tip brackets. Securing is especially advisable for taller units.
- Cutting and adjustment: Ikea allows trimming Pax units. If your basement ceiling height is less than 2.10 meters (6 ft 11 in), you can customize the frames to size, making sure connections are securely tested. Alternatively, you can stack smaller, lower frames on top of each other.
- Organization: For storage in the basement, I recommend using sturdy, stackable plastic boxes with lids that can be integrated into the Pax or placed on shelves. Accessories like hanging rods are less suitable here. Drawers and basket inserts are more practical.
- Appearance: The look in the basement is usually of secondary importance, but a white or light-colored finish can brighten the space. Also, pay attention to surfaces that are easy to clean.
Conclusion: With proper preparation and adjustments, you can use Pax units effectively in the basement as long as you manage moisture issues and carry out installation carefully.
Hello Nemau,
I have installed Pax multiple times in basements and can provide a simple 3-step tutorial on how I approached it:
1. Preparation:
- Measure the room’s humidity and use a dehumidifier if needed.
- Check the floor with a spirit level and even out any unevenness using felt pads or wooden wedges.
2. Adjustment:
- If necessary, shorten the frame panels to match the basement height – I used a jigsaw with a fine-toothed blade for this.
- Paint parts separately to increase protection against moisture.
3. Installation:
- Use sturdy, stackable plastic bins that fit well within the internal dimensions of the Pax.
- Install drawers only where frequent access is needed; use fixed shelves elsewhere.
- Add extra metal brackets for more stability at attachment points.
This way, the wardrobe is sturdy, functional, and protects your items.
That’s exactly how I did it. Avoiding floor contact especially protects against moisture damage.
I recommend checking the measurements carefully before purchase and being prepared for mid-height or frame modifications.
If you have any questions about assembly or materials, feel free to ask.
1. Preparation:
2. Adjustment:
3. Installation:
Leonardteo schrieb:
A basic treatment with waterproofing or placing the unit on plastic feet to avoid direct contact with the floor can help.
