ᐅ Are there any experiences with Ikea Pax wardrobes in damp or humid rooms?
Created on: 19 May 2023 18:03
V
viktors64
I am currently planning to install a large Ikea Pax wardrobe in a damp room, specifically a windowless bathroom, for storing towels and bathroom accessories. I am concerned about whether the Pax systems are suitable for this purpose—mainly regarding potential moisture-related damage such as swelling of the panels, mold growth, or damage to the hinges and fittings.
Does anyone have experience with Ikea Pax wardrobe elements under such conditions? Insights on long-term performance, special protective measures, or recommendations for alternative furniture suitable for damp rooms would be very helpful.
I look forward to your factual reports and any tips on water repellent treatments or ventilation.
Thank you in advance!
KIN42
20 May 2023 10:50
Regarding the matter:
Particle boards are susceptible to moisture. The melamine coating offers only limited protection since cut edges and corners remain exposed. Therefore:
- Seal all edges with an additional water-resistant varnish to extend durability.
- Do not place the cabinet directly on the floor; use feet or legs to prevent moisture from the floor from rising.
- For damp rooms, it is better to choose furniture with solid plastic surfaces.
This significantly reduces the risk of damage.
reni45
20 May 2023 12:15
Briefly my experience: A Pax wardrobe in a damp room is not a must. If you use the wardrobe, make sure to leave some space from the wall and ensure it does not get wet. Ventilation is also essential.
Hanging wet towels directly inside is not an option.
V
viktors64
21 May 2023 14:47
Thanks for the many helpful responses so far. Here is a brief summary of what I have gathered:
- Ikea Pax is not originally designed for long-term exposure to moisture due to the particleboard and the edges.
- It is important to maintain a distance from damp walls and ensure good air circulation.
- Sealing the edges can help, but it requires effort.
- Do not store wet items directly in the cabinet.
Does anyone in the community have specific experience with this? Are there cases where a Pax has been used in a bathroom for several years without damage, or have there been problems despite all precautions?
This information would help me decide whether I can take the risk or if I should look for an alternative.
angel
21 May 2023 16:21
viktors64 schrieb:
Does anyone here have specific experience: Are there cases in the community where a Pax has stood in a bathroom for several years without damage, or were there problems despite all precautions?
Yes, I can confirm that in my case it actually worked for over 3 years without major issues, but the bathroom had good ventilation and the cabinet was placed with some distance from the wall. In winter, I made sure to keep the room temperature stable to minimize condensation.
Still, the risk remains, especially if moisture accumulates behind the cabinet or humidity stays high for extended periods; in my case, the edges gradually started to chip away.
My advice: If you can’t reliably keep humidity low, it’s better to choose different furniture.
Luciandi
21 May 2023 19:38
I feel the same way as viktors64: I originally wanted to use PAX, but then I chose a moisture-resistant version made of plastic. The investment was higher, but especially in a bathroom with high humidity, it’s worth it for greater peace of mind.
It is true that very cautious measures can protect PAX, but the risk of premature damage remains. Also as a tip: a hygrometer can help monitor the humidity levels and allow you to take action if needed.
I would have appreciated reading more long-term experiences here beforehand.
