ᐅ How can I use Ikea Besta units for storing large and bulky items?
Created on: 2 Oct 2021 08:24
REORA
I am planning to use my Ikea Besta as storage, but I specifically want to accommodate large and bulky items. I am generally familiar with the Besta system, but the shelves are usually designed for smaller items. My question is therefore: How can I best modify or use Ikea Besta to store bulky things like larger boxes, books, or sports equipment without compromising stability or making it impractical? Are there any useful tips for assembly or interior organization that I should keep in mind? I look forward to your experiences and advice!
klo40
2 Oct 2021 16:23
Tevin schrieb:
Besta can also be used as an open shelving system, which offers the advantage of greater flexibility.
Exactly, and here is an important tip: If you use the Besta completely open and avoid doors, you should definitely secure the back panel firmly and stably. This prevents warping under heavy loads and significantly increases safety.
Additionally, you can cut custom shelves if needed, which are not included with Besta by default, allowing you to adjust the height individually.
Leonardteo
3 Oct 2021 07:11
In addition to the previous comments: If the items are very heavy and bulky, it is advisable to reserve and use the lower compartments more intensively. This reduces the load on the upper shelves and creates a more stable overall structure.
Furthermore, it is worth considering connecting individual Besta units to create a larger, integrated storage system tailored to the room. This allows for better and safer storage of larger objects.
Z
zartra
3 Oct 2021 09:45
Always keep the back panel in place. Large, bulky items require more stability.
Remove shelves as needed; otherwise, simply make use of Besta's full depth.
WARREN
3 Oct 2021 11:23
I have often used Besta carcasses without doors for bulky items. Instead, I use boxes and baskets. This way, everything remains flexible and accessible.
BARSAN
3 Oct 2021 12:06
LEONARDTEO schrieb:
reserve and reinforce the lower compartments.
Exactly. Additionally, you can reinforce the lower compartments with a thin wooden board if the large items are very heavy.
REORA
4 Oct 2021 08:52
Thank you for your numerous and detailed tips! To summarize, I learned that using fewer shelves can create more storage space, firmly securing the back panel is essential for stability, and using box options (also from other Ikea systems) is recommended.
I will probably put together an open Besta shelving unit to remain flexible and be able to store large items without door clearance issues.
I have one last question: Are there proven ways to adjust the height of individual compartments without using standard shelves—such as custom-made solutions or divider systems? That would be very practical to optimize the available space.
