ᐅ How can I sustainably recycle Ikea Hemnes furniture?
Created on: 7 May 2024 08:17
ENRICO30
ENRICO30
7 May 2024 08:17
I currently have several Hemnes furniture pieces from Ikea at home, including dressers and nightstands. Since I am redesigning and planning to replace some of the furniture, I am considering how to recycle them as sustainably as possible.
The Hemnes furniture is mainly made of solid wood or partially veneered, but I am unsure whether I should simply dispose of them or better dismantle the pieces to reuse or recycle individual components.
I am also interested in whether there are specific local or regional disposal options for this type of furniture that minimize resource consumption.
Does anyone in the forum have experience with environmentally friendly recycling of Hemnes furniture? Maybe some upcycling ideas, tips for dismantling, or advice on suitable recycling centers?
I look forward to your expertise and practical solutions, preferably with background information on material treatment or sustainable use of the wood remnants!
koduga
7 May 2024 09:05
Hello Enrico,
I completely understand that sustainability is important to you when it comes to furniture. Hemnes furniture is solidly built, but this can make recycling more difficult if the parts are glued together or coated with finishes.
I have personally taken apart Hemnes dressers twice and tried to reuse the wood. I noticed that it’s best to fully disassemble the pieces using a cordless drill – remove nails and screws so you’re mainly left with wood panels and solid wood.
ENRICO30 schrieb:
I’m also interested to know if there are special local or regional disposal options for this type of furniture that help minimize resource consumption.
I would suggest calling your local recycling center or waste facility to ask if they accept the wood as firewood or for industrial processing. If the wood is finished with paint or lacquer, it is often recycled as fuel for incineration.
In my opinion, the most important step is to disassemble the furniture, as this often allows for reusing old wood in other ways, such as for craft projects, shelving boards, or as firewood if it is untreated.
Hope this helps you a bit!
Surela
7 May 2024 10:29
Hello Enrico,
I’m taking a somewhat more technical approach to the sustainable disposal of Hemnes furniture because I want to consider all details.
First of all, you should check the exact composition of your furniture: Hemnes is usually made of pine wood, sometimes with surface treatments (paint, stain) or veneered central parts. This means that pure reuse or raw material recycling is only possible if the surface chemicals are removed – which is difficult to do at home.
- Step 1: Carefully disassemble the furniture, removing screws and metal parts.
- Step 2: Check which wood parts are painted or treated. For painted areas, I recommend sanding them down if you plan to reuse them.
- Step 3: Sort the wood – separate solid wood from particleboard, as particleboard contains adhesives and is unsuitable for open burning.
- Step 4: The solid wood parts can then be used well for upcycling projects – for example, as wall shelves, tops, or garden furniture if they are properly re-treated.
ENRICO30 schrieb:
Are there any experiences in the forum regarding how you have recycled Hemnes furniture in an environmentally friendly way?
Yes, I have also made smaller shelf parts from Hemnes dressers, and my tip is: depending on the condition, simply sand the surface and treat it with oils instead of paint – this significantly improves sustainability.
Regarding disposal:
- Local recycling centers often accept untreated wood but not painted panels.
- Furniture retailers like Ikea occasionally offer take-back services, so check with them.
If you like, I can provide more detailed information on sanding methods and suitable materials.
KLO-KA
7 May 2024 11:11
Disassemble Hemnes wood, remove screws. Solid wood can be reused or used as firewood. Particle boards should preferably be taken to a recycling center. Ikea accepts old furniture back if you book a pickup service.
TEOZAR
7 May 2024 13:47
Hello Enrico,
I completely agree that sustainable disposal is very important when it comes to Hemnes furniture. Since Ikea Hemnes is mainly made of solid wood, reusing the individual parts is ideal – as has already been mentioned.
A few tips from my experience:
- Take the furniture apart as completely as possible (remove screws and metal parts)
- Intact building materials can be offered for sale at secondhand stores or on online platforms
- Small wood scraps can be used to create DIY projects like wall shelves, birdhouses, or planter boxes
- Furniture parts that can no longer be used can often be properly disposed of at recycling centers – the wood is then processed industrially on site
If you’re interested in upcycling: with some sanding and an appropriate finish, the material can remain usable for many more years.
This contributes greatly to resource conservation.
I hope these suggestions help you!
flo-Theres
7 May 2024 16:22
There is one more important point I would like to add: The surfaces of Hemnes furniture are often painted or coated, which makes composting or recycling more difficult because paints and coatings can contain harmful substances.
This means that recycling centers usually only accept untreated or mechanically unprocessed wood waste. If you sand the surfaces, you remove part of the paint layer, which improves the possibility of reuse; however, you should wear appropriate respiratory protection masks while sanding.
That sums it up well. Please do not dispose of particle board in organic waste bins, as they contain adhesives that are not compostable.
In summary: disassemble, sort, avoid painted surfaces where possible, and check with your recycling center.
Perhaps you can also consider donating furniture to a nonprofit organization if it is still in good condition, as this significantly extends its lifecycle.
