ᐅ How can I securely install Ikea Metod cabinets on uneven or sloping walls?
Created on: 26 Feb 2021 08:17
teojamie51
Good morning everyone, I plan to install Ikea Metod kitchen cabinets in my apartment, but I’m facing the problem that the walls here are quite uneven. The irregularities and slopes are sometimes more than 2 cm (0.8 inches) over a length of 2 meters (6.6 feet). How can I still mount the Metod cabinets securely and level so that they stand safely and straight, without causing any future structural or functional issues? I’m open to tips on leveling, fastening to the wall, and possible alternative solutions if the Ikea mounting system has limitations in this regard. Thanks in advance for your opinions and experiences!
LOJOPAR
27 Feb 2021 08:18
teojamie51 schrieb:
Would it be advisable to secure or stabilize the cabinets to the floor if the walls are really uneven?
Good question! Generally, Metod cabinets are designed for secure wall mounting, but floor fixing or additional supports are not prohibited. The main goal is structural stability.
If the cabinets only rest on the floor, they can shift or tip, so wall mounting is important. When the wall is uneven, adjustable system legs can be used at different heights to ensure the cabinet sits level on the floor, in addition to wall mounting.
Make sure the floor and wall fixings work together as a stable unit. If you decide to add floor fixings, they should be properly secured like with screws – this greatly improves stability on sloped surfaces.
In short: yes, floor supports are possible and often helpful, but they do not replace wall mounting; rather, they complement it.
teojamie51
27 Feb 2021 08:52
LOJOPAR schrieb:
Make sure that the floor and wall fixings form a stable unit together.
Thank you for the detailed explanation; it helps me a lot with the planning. I will install a mounting batten, use shims for adjustment, align the cabinets precisely, and then work with adjustable feet on the floor. I hope this way I can achieve a good balance between stability and a straight appearance.
dijan
27 Feb 2021 09:11
Sounds good, especially the adjustable feet are great for uneven floors. One small tip: choose feet that can be easily and precisely adjusted, so you still have some flexibility if the wall shifts slightly.
BARSAN
27 Feb 2021 09:28
Be careful: When securing the floor, always check whether the subfloor absorbs moisture, as this can cause issues. Untreated wooden battens are often susceptible in such cases.
pinpa
27 Feb 2021 09:45
To lighten the mood a bit: If the walls are already uneven, then the refrigerator can afford to stand a little crooked, right? 😉 Jokes aside, with proper preparation, you won’t notice the unevenness much later on, fortunately.
GLAEL
27 Feb 2021 10:02
Quite pragmatically: You can also secure all cabinets at the bottom to the floor using brackets and angle screws. This way, you can be more relaxed about mounting them to the wall. The important thing is that none of the cabinets wobble, and you can use any means to prevent that.
