ᐅ How can I secure Ikea Metod cabinets to prevent them from shifting on uneven floors?
Created on: 2 Jan 2017 08:13
Listu50
Hello everyone, I recently bought some Ikea Metod kitchen cabinets and want to secure them safely against slipping on an uneven floor. The room where the cabinets are installed unfortunately has a slightly uneven screed, which causes the cabinets to be slightly unstable and move forward or sideways when loaded. My question is: What methods or tools do you recommend to reliably prevent Metod cabinets from slipping or tipping on uneven floors? I’m looking for sturdy solutions that are practical without having to fully level the floor. Thanks in advance for your advice!
Listu50
2 Jan 2017 11:02
Louie schrieb:
What is the composition of the floor material? Stone? Laminate? That also matters.
Thank you in advance for the answers! The floor is an old tiled screed with large joints and is generally quite uneven – when I measure with a spirit level, there can be up to a 12mm (0.5 inches) difference over 2 meters (6.5 feet). My problem is less about tilting, since I actually set up the cabinets with adjustable feet and installed the wall mounts from Ikea. My real concern is sliding. The cabinets aren’t heavily loaded, yet they noticeably shift when I open the doors or take items in and out. Perhaps a smart method of securing them to the floor is missing here.
fidasi
2 Jan 2017 11:46
Listu50 schrieb:
My problem is less about tipping since I actually set up the cabinets with adjustable feet and also installed the IKEA wall mounting.
It’s great to hear that you have stability against tipping. Regarding sliding: since the tiled screed with grout lines is the issue here, rubber pads with high friction are certainly better than felt. I would specifically recommend using non-slip mats designed for furniture, simply cutting them to fit under the feet.
Alternatively, you might consider adding grooves or small support strips on the floor that act as a sort of “brake.” That could be worth thinking about.
One more idea: Is it possible to secure the cabinets directly to the floor using a sturdy base profile or skirting boards? This can be done with small brackets or metal plates that are both discreet and stable.
pinbo
2 Jan 2017 12:07
Listu50 schrieb:
I am really concerned about the cabinets shifting.
In this case, you should also consider how the forces occur when opening the cabinets. Sometimes sliding the doors causes horizontal forces, especially if the doors are stiff or the floor is very smooth.
I would combine the cabinets with a floor attachment that does not penetrate the floor directly, such as small adjustable floor rails or special anti-slip pads that work over a large area to prevent rolling. Often, simple self-adhesive rubber mats under the feet that increase friction are already helpful.
Another option is to connect the cabinets to the back wall structure and reinforce it so that it is anchored to the floor, for example with small battens fixed to the floor.
meole
3 Jan 2017 07:18
I know it’s frustrating when cabinets aren’t stable. I had a similar issue with old tiles. I finally succeeded by combining non-slip rubber pads under the cabinet feet with shallow wooden strips fixed to the floor in front, so they can’t slide forward.
It’s also important that the cabinets are securely connected to each other, otherwise one movement can amplify another.
You’re on the right track with the adjustable feet and wall mounting. Maybe adding wooden strips fixed to the floor will completely solve the problem.
BARSAN
3 Jan 2017 08:45
I always use non-slip rubber mats under the feet. For very uneven floors with larger gaps, you can also use sturdy wooden wedges to level the space. Assemble cabinets and secure them to the wall – this usually works without any issues.
Louie
3 Jan 2017 11:00
meole schrieb:
Maybe fix wooden strips to the floor, then the problem is solved.
Exactly, wooden strips or thin baseboards are a simple and effective solution that can be installed inconspicuously. They prevent the feet from slipping forward under pressure. Just make sure the strips are firmly attached to the floor and adjusted to the correct height.
