ᐅ How can I securely install Ikea Metod cabinets on uneven or sloping walls?
Created on: 26 Feb 2021 08:17
teojamie51
Good morning everyone, I plan to install Ikea Metod kitchen cabinets in my apartment, but I’m facing the problem that the walls here are quite uneven. The irregularities and slopes are sometimes more than 2 cm (0.8 inches) over a length of 2 meters (6.6 feet). How can I still mount the Metod cabinets securely and level so that they stand safely and straight, without causing any future structural or functional issues? I’m open to tips on leveling, fastening to the wall, and possible alternative solutions if the Ikea mounting system has limitations in this regard. Thanks in advance for your opinions and experiences!
teojamie5127 Feb 2021 10:25Thank you for the assessments regarding the ground reinforcement! The whole project is turning into an exciting mix of planning and hands-on work backed by solid technical knowledge. All the input really helps me evaluate the best solution. If I have any more questions, I will reach out again!
SauDietmar27 Feb 2021 11:01One final tip: Try to avoid making too many adjustments directly on the cabinet. It is better to compensate for unevenness beforehand on the wall or mounting strip. This keeps the entire system stable and organized.
Exactly, and if you approach the installation in several stages—first the trim, then the cabinets, followed by fine adjustments—the final result is usually much better than trying to do everything at once. This way, you also maintain control over each step and can make corrections if necessary.
