ᐅ How can I secure Ikea PAX wardrobes to prevent them from tipping over accidentally?
Created on: 21 Jun 2019 08:37
Faikla
Faikla
21 Jun 2019 08:37
Hello everyone, I have several Ikea PAX wardrobes at home and I am increasingly concerned about their stability. Specifically, I am wondering how to best secure these PAX wardrobes against accidental tipping. My apartment has uneven floors in some areas, and I am worried that especially with open doors or when children are nearby, there is a risk that the wardrobes could tip over. I am looking for practical and safe methods for securing them, preferably ones that are recommended or tested by Ikea. What are your experiences or recommendations? Are there specific wall brackets, anchors, or other tricks to improve the stability and safety of PAX furniture? Thanks in advance for your advice!
LUSAR
21 Jun 2019 09:15
The best and safest way to secure Ikea PAX wardrobes against tipping is to use the included wall fasteners. It is important that:
- The wardrobe is leveled before installation to minimize rocking.
- The wall fasteners are firmly and properly screwed into suitable wall materials (e.g., solid wood, concrete).
- Avoid fastening directly into drywall without appropriate anchors or reinforcements.
- Additionally, the level adjusters on the feet of the PAX wardrobe series can be used to improve stability.
This is the safest, easiest, and most cost-effective method recommended by Ikea itself.
ritotar
21 Jun 2019 11:22
LUSAR schrieb:
Before installation, the cabinet should be leveled to minimize tipping movements.
Absolutely! I underestimated this at first and only discovered the small adjustment screws on my PAX afterward – a real lifesaver 😅. One more tip: If you have young kids, I strongly recommend properly anchoring these cabinets. Not just for stability, but because little ones can get quite mischievous. And yes, I’m a fan of safety with a touch of humor. So, get those screws tightened, everyone! 👍
BEATE
21 Jun 2019 13:03
Use wall fastenings. Level the floor using adjustable feet. Do not overload the cabinet. That is sufficient.
Katau
22 Jun 2019 07:56
Most users rely on the supplied fasteners, right? However, it is important to always check the type of wall structure before installing the wall bracket. For drywall (plasterboard) walls, simple anchor installation is usually not sufficient. In this case, either special hollow wall anchors should be used or the screws should be fixed into load-bearing elements (such as wooden studs behind the wall).
Additionally, it should be considered that the PAX may still tip over despite being secured if it is heavily loaded or overloaded. Therefore, it is also important not to overload the upper cabinet areas to keep the center of gravity low.
Faikla
22 Jun 2019 15:14
Katau schrieb:
For drywall partitions, a simple plug anchor installation is usually not sufficient.
Thank you for the tip. My apartment does indeed have some drywall partitions. Is there a specific recommendation on which anchors or fasteners work best in such cases? Also regarding load capacity?
And one more question: Some users connect several PAX wardrobe modules together. Does this add extra stability, or could it actually increase the risk of tipping?
