ᐅ How can I secure Ikea BESTA furniture to prevent tipping, especially in households with children?
Created on: 14 May 2020 08:23
teka4Hello everyone,
I recently set up some Ikea Besta furniture pieces in our home. Since I have young children, I’m concerned about their stability and how to secure this furniture against tipping over. My specific question is: What options and products are available to effectively secure Ikea BESTA furniture against tipping, especially regarding safety in households with small children?
I am interested both in wall-mounting solutions and possible alternative securing methods. Is there anything specifically designed for BESTA, or are universal solutions sufficient? And what experiences have you had with installation and the reliability of the different methods?
Thanks in advance for your tips and recommendations!
Hi,
first of all, it is true that securing furniture against tipping is an absolute must, especially in homes with children. However, there are a few points to consider before blindly attaching everything to the wall. For example:
- How sturdy are the walls really? Drywall is less load-bearing than solid masonry.
- How much load can the safety fixings actually handle?
Many Ikea BESTA units have a certain inherent stability, especially when assembled according to instructions and properly leveled. Still, the recommended wall brackets are basically a standard, and are often included in the delivery. It is, however, uncertain whether these are sufficient if children try to climb on the furniture, for example.
So the question arises: Is wall mounting alone enough, or should additional measures such as floor anchors be considered?
Who has experience with how stable the official securing systems really are and what loads they can withstand?
pauPierce14 May 2020 13:52enrique7 schrieb:
Many Ikea BESTA units have a certain level of stability on their own, especially when assembled according to instructions and properly aligned.This is an important point I would like to add to. Securing BESTA furniture against tipping is practically mandatory by attaching it to the wall since the furniture is relatively light and tall. The following points should be considered:
- Ideally, use the wall mounting kits supplied by Ikea. These are precisely designed and tested for the BESTA series.
- Pay attention to the correct type of wall anchor depending on the wall (e.g., expansion anchors for concrete, specialized anchors for drywall), as improper wall fixing can significantly reduce effectiveness.
- Install the furniture flush and precisely aligned at floor level whenever possible to minimize tipping risks.
- An alternative is additional corner brackets or special furniture anchors that connect the furniture to the wall.
Furthermore, I recommend avoiding storing heavy items on top of the furniture, as this shifts the center of gravity unfavorably.
One question that remains for me is whether anyone has experience with additional safety measures that not only anchor to the wall but also secure the furniture to the floor, as this could be especially relevant in homes with children.
I can fully understand the concern – as a father of two young children, we spent a lot of time thinking about tip-over prevention.
After some research and testing, we secured our BESTA furniture to the wall using the included brackets, but we also attached additional metal corner braces to the back. We anchored these braces into the wall, which in our case is solid brickwork.
Additionally, we installed child safety locks on all the doors, since the furniture can feel somewhat unstable when curious little hands try to hold on or climb up.
From my experience, wall mounts are always necessary, but for active children, it is definitely safer to reinforce the furniture further.
I also avoid placing the furniture directly in areas where the kids climb or play a lot. Keeping a safe distance from play areas is another good safety measure.
enrique7 schrieb:
Is attaching it to the wall alone enough, or should other measures like floor anchors also be considered?
I think the discussion about securing BESTA furniture is somewhat exaggerated.
Of course, safety should be a priority, especially with children around, but I believe many of the recommended precautions are just alarmist. Do furniture pieces tip over? Yes, if they are set up incorrectly or children are allowed to do things they shouldn’t.
If children climb on furniture, it’s really the parents’ responsibility to teach them not to, rather than barricading every piece of furniture.
In my opinion, the original wall mounts are completely sufficient. Those who want more secure setups can build sturdier furniture or change how the space is used.
But of course, opinions will probably differ here. I see safety concerns, but also some uncertainty about parenting.
relupa schrieb:
Additionally, we put child safety locks on all the doors because the furniture can seem a bit unstable when curious hands try to grab onto it or climb up.
pauPierce16 May 2020 07:05NOAHSAU schrieb:
If children climb on furniture, it is actually the parents' responsibility to not allow it, instead of barricading every piece of furniture.I see this somewhat differently. Of course, education is part of it, but especially with small children, curiosity and clumsiness are part of their development.
Technical safety systems, such as wall brackets, should therefore not be seen as a replacement for education, but as a complementary measure to prevent accidents – which mainly happen when you are not paying attention.
A few technical tips regarding the installation of the original Besta wall brackets:
- They should be screwed in the upper third of the furniture to best prevent tipping.
- With drywall (plasterboard) walls, always use appropriate anchors (e.g., cavity anchors, toggle bolts) and, if possible, mount on stable studs.
- If it is possible to install an L-shaped bracket with floor anchoring as well, this increases stability.
If the original poster can provide more details about their living situation (wall type, furniture projection, etc.), I would be happy to give more detailed advice.
