ᐅ How can I safely store heavy equipment in IKEA BESTA units?
Created on: 18 Aug 2020 21:07
liedwin66
liedwin66
18 Aug 2020 21:07
Hello everyone, I am currently looking into how to safely and securely store heavy items—such as larger electronics, tools, or heavy kitchen appliances—in IKEA Besta cabinets. The Besta modules are quite versatile, but I’m concerned about the load capacity of the shelves and the overall stability.
Specifically, my question is: What measures do you recommend to reinforce the shelves so they can safely hold heavy loads? Are there special fittings, alternative materials, or modifications that make sense?
What weight limits should ideally not be exceeded based on your experience? And how does the general stability of the Besta series hold up when loaded with heavy equipment and possibly rearranged or moved?
I’m looking forward to your tips and experiences, including advice on the optimal distribution of weight within the cabinet.
Jaime
19 Aug 2020 08:23
The official load capacity of the Bestå shelves is approximately 10-15 kg (22-33 lbs) per board when used in the standard configuration, which can be quickly reached with heavy appliances.
To address your concern, I recommend the following approach:
- Reinforce the shelves with additional plywood or thick MDF panels (at least 18 mm (0.7 inches)) placed on top of or replacing the original shelves.
- Use extra center supports or legs to prevent sagging.
- Distribute heavy appliances mainly on the lower compartments to improve the overall cabinet’s stability against tipping.
Additionally, I would recommend securely anchoring the cabinet to the wall using the supplied mounting hardware, especially when it is heavily loaded.
These measures will significantly increase stability and reduce the risk of shelf breakage or tipping.
Ethan
19 Aug 2020 11:17
Jaime schrieb:
Distribute heavy equipment preferably to the lower compartments to improve the overall cabinet’s tipping resistance.
This is a very important point that I want to emphasize. The principle of storing heavy loads at the bottom not only provides better stability but also reduces the stress on the connections between the individual modules.
Additionally, when storing large equipment, attention should be paid to the cabinet size and configuration: wider modules often have more stable shelves, and adding cross braces or solid back panels can help distribute the load more effectively.
If you want to secure your equipment rather than just place it inside, anti-slip mats can prevent the items from sliding, especially when opening doors or moving the modules.
Ultimately, stability also depends on assembly quality: screws should be tightened properly, and if possible, all wall brackets should be used to prevent tipping.
maureo
19 Aug 2020 14:41
Use stronger floors and install additional supports.
Keep heavy items on the lower levels.
Securely attach the modules to the wall.
Landontau
20 Aug 2020 07:59
Here are some structured tips regarding heavy equipment in IKEA BESTA:
- Load analysis: First, determine the exact weight of your devices. A realistic weight per shelf is 10-15 kg (22-33 lbs), but with the IKEA particleboard shelves, this limit is quickly reached.
- Shelf reinforcement: Replace the shelves with sturdy, custom-made boards made of plywood or MDF (at least 18 mm (0.7 inches) thick) or lay an additional plywood sheet across the original shelf.
- Support braces: Add a metal bracket or crosswise battens underneath the shelf, screwed into the inner side of the cabinet frame. Alternatively, small adjustable furniture feet under the shelves in the center can help relieve pressure.
- Load distribution: Place the heaviest devices only in the lower compartments and distribute the weight as evenly as possible to avoid localized overloading.
- Cabinet anchoring: Use the included wall anchors to secure the cabinet firmly to the wall structure (e.g., masonry or load-bearing wood). Rigidity against twisting is a crucial factor when carrying heavy loads.
- Door and back panel options: Fixed back panels made of particleboard noticeably increase cabinet stability; open-back versions may lack sufficient bracing.
- Assembly: Tighten all screws and, if possible, replace them with larger screws for stronger hold.
By following these steps, you can store your heavy equipment safely and securely in BESTA. For very heavy loads, however, I would recommend independent, sturdy metal shelving, as BESTA is designed for light to medium loads.
