ᐅ Which LED lighting systems work well with IKEA Besta furniture?
Created on: 29 Jan 2024 19:07
farfernand
farfernand
29 Jan 2024 19:07
Hello everyone, I am planning to equip my IKEA Besta system with LED lighting and I am looking for recommended LED lighting systems that suit the furniture well, both technically and visually. It is important to me that the lighting integrates seamlessly with the modularity and design of the Besta units, can be mounted discreetly if possible, and ideally offers dimmable, warm light. Which products or systems have you used that fit nicely into the shelves? Are there any specific recommendations regarding power supply (e.g., 12V, 24V, or directly 230V), control compatibility (remote control, app, switch), or installation? I look forward to your suggestions and experiences!
Davidleo
29 Jan 2024 20:15
Hey, great question! I installed a 12V LED strip system from Philips Hue on my Besta shelf and I’m really impressed! The installation was very easy since the LEDs are self-adhesive and I could cut the strip to the right length as needed. The best part is that you can control the light color through an app, and the warm white looks really cozy. If you’re a bit tech-savvy, you’ll have a lot of fun with it! Highly recommended—it really creates a great atmosphere in your living room! 😊
kasan
29 Jan 2024 21:03
I would like to clarify something here: LED strip systems are flexible and easy to hide, but from a technical standpoint, you should also pay attention to the quality of the drivers and heat generation. Some inexpensive 12V systems tend to flicker more quickly or experience color temperature drifting. Additionally, the choice of control method is important: app-based systems are convenient, but they depend on wireless standards and software updates. Why not also consider testing simple 230V LED panel lights under the shelves, which can be screwed directly into the Besta panels? This could be a stable, long-lasting solution for you.
Nathanaelk
29 Jan 2024 22:47
Regarding farfernand’s question: If you want to illuminate a Besta shelf unit, it depends on the exact purpose of the lighting—ambient light, accent lighting, or task lighting. For high-quality light, it is recommended to use LED modules with a high color rendering index (CRI > 90) and a warm white color temperature (around 2700–3000K). I usually use flexible LED strips with aluminum profiles to achieve even light distribution. You can simply screw the profiles under the shelves, which also helps prevent overheating. It is also important that the driver has at least 80% efficiency to avoid wasting energy unnecessarily. Question for farfernand: How many meters (feet) do you want to illuminate, and should the LEDs be directly visible or preferably hidden under the shelves?
farfernand
30 Jan 2024 08:14
Nathanaelk schrieb:
Question for farfernand: How many meters do you want to illuminate, and should the LEDs be directly visible or concealed under the shelves?
Thanks for asking – it’s definitely important for me to have a discreet solution that doesn’t look like a light fixture at first glance. I’m planning a total lighting length of about 3 meters (10 feet), spread across several shelves. Mainly ambient lighting that isn’t too bright and creates a warm atmosphere. I don’t need task or reading lights in the Besta. Do you have any specific LED modules with compatible aluminum profiles in mind that are easy to install and reliable?
Palenar
30 Jan 2024 10:52
For discreet lighting over a length of about 3 meters (10 feet), in my experience, a warm white LED strip (2700–3000K) with at least 120 LEDs per meter (30 LEDs per foot) works well. Why? A higher LED density ensures more even light distribution, with no visible flickering or gaps between the LEDs. Combined with slim aluminum profiles (e.g., 10x10 mm (0.4x0.4 inches)), you can neatly install the strip under floors. If cable connections are an issue, using solderless connectors is a good option. Dimmable drivers with PWM control can be operated via simple rotary dimmers or even Zigbee components. Also consider heat dissipation: aluminum profiles significantly extend the lifespan of the LEDs. Additionally, for control systems, I recommend at least IP20 protection if there is a chance of moisture in the room.
