ᐅ How can I retrofit Ikea Metod cabinet doors with soft-close hinges?
Created on: 30 Jul 2022 09:13
jeritauHello everyone,
Some time ago, I put together an Ikea Metod kitchen unit, and now I feel it’s missing that certain something: the soft-close function for the doors. Therefore, I would like to know specifically how to retrofit Ikea Metod doors with soft-close. It is important to me that the solution is as discreet as possible and compatible with the existing hinges. Which products are reliable, how complex is the installation on existing doors, and what should I pay special attention to so that the doors close smoothly and quietly?
For all the details: These are the classic Metod doors with the standard hinge type (cup hinge) from Ikea. If there are any differences, it would be great to know exactly what to watch out for.
Looking forward to your tips and experiences!
Sinan-meo30 Jul 2022 10:24jeritau schrieb:
Therefore, I would like to know specifically how to retrofit soft-close functionality to Ikea Metod doors.Hello,
Retrofitting soft-close functionality for Ikea Metod doors is generally possible because Ikea offers compatible soft-close dampers that can be attached to the cup hinges. It is important to know the exact model, as there are different versions of the Metod hinges.
The installation steps are quite straightforward: first, open the door, clip the damper onto the hinge, and secure it with the integrated screw. A full hinge replacement is not necessary. Make sure the door is properly aligned when closing, otherwise the soft-close function may not work optimally.
If you have a different type of hinge, universal soft-close adapters might be an option; these are placed simply between the hinge and the cabinet frame.
I also recommend carefully following Ikea’s own retrofit instructions, which explain all the details of the installation. Good luck!
A mini tutorial for retrofitting the soft-close function on Ikea Metod doors:
- Step 1: Check your existing hinge type. For the standard Metod cup hinges, Ikea offers specific soft-close attachments.
- Step 2: Purchase the appropriate soft-close dampers designed for your hinge type. There are different models, such as the "Väggis" or "Metod" dampers.
- Step 3: Remove the doors from the hinges to make installation easier.
- Step 4: Clip the soft-close damper onto the existing hinge, usually secured with a small tightening screw.
- Step 5: Rehang the door and test the closing. Fine adjustments can be made via screws on the hinge to achieve perfect closing.
Common mistakes include buying the wrong damper or incorrect alignment of the damper, which prevents the soft-close function from working properly.
Summary: Ikea offers simple retrofit solutions that require minimal tools; you just need to choose the correct damper for your specific hinge model.
taudi schrieb:
Check the type of hinge you currently have. This is the most important step. If you don’t do this, you might buy the wrong parts.
Soft-close dampers are available either directly from Ikea or as universal versions that fit into the hinges.
Installation is usually a snap-on system, requiring minimal effort.
Matthewt4831 Jul 2022 08:59Hello jeritau,
I understand that you want an easy and clean way to retrofit the soft-close feature. From my own experience with Ikea Metod kitchens, I can share the following:
The Ikea soft-close dampers are actually designed to complement the existing hinges without needing a full replacement. Installation is user-friendly and usually only requires a screwdriver.
It’s important to check the hinge type carefully before purchasing, as there are variations. Ordering the wrong model might result in the dampers not fitting or not working properly.
If you are somewhat handy, you should be able to install the dampers for the entire kitchen in about 15–30 minutes, depending on the number of doors.
Protect the doors well during the work to avoid scratches, and check that the hinges are securely fastened before attaching the soft-close dampers.
If you have any questions, just let me know!
Matthewt48 schrieb:
The installation is tool-friendly, usually just a screwdriver is enough.Exactly!! 😊
I also retrofitted my Metod doors, and it’s really enjoyable and adds so much convenience! Such a quiet, smooth closing makes a big difference!
As mentioned, it’s important to order the correct damper. After that, just get to work on the door – the clip system is super easy!
So go for it – retrofitting is definitely worth it!
