Hello everyone, I have a problem with the door spring on my Ikea Metod kitchen cabinet and am urgently looking for a precise and reliable guide for repair or at least troubleshooting. The spring is only partially working now; the door no longer closes properly and feels somewhat loose. It is the integrated door spring that controls the closing action, not an additional soft-close mechanism.
I want to understand whether the spring can be replaced by myself, if there are spare parts available from Ikea or third-party manufacturers, or if it is possible to adjust or retension the spring in some way. Are there specific tools I should be aware of? And what should I pay attention to when removing and reinstalling the door to avoid damaging the door or the cabinet frame?
I would greatly appreciate concrete tips, experiences, or advice on possible causes of failure, as I want to avoid having to replace the entire door or ordering unnecessary spare parts.
Hello jajim,
First, some technical background: The door spring in the Ikea Metod kitchen modules is usually a steel tongue or metal spring housed in a plastic holder. The most common reasons for a weak or failing spring are a break, material fatigue, or a displaced holder.
- For removal: You need to unhang the door, which can be done either by loosening the hinge screws or by unlocking the hinges in a specific way. Check the IKEA instructions for this, as hinges are sensitive and should not be twisted.
- After that, it is advisable to check the spring attachment. If the spring is mechanically damaged, you can often replace it if you have the correct replacement spring. Unfortunately, Ikea often only sells complete hinge sets or door dampers; the spring alone is rarely available as an original spare part.
- Some users have had good experiences with similar spring packs from hardware stores, such as furniture fitting products. However, pay attention to the dimensions and spring tension.
- If the spring is only loose, a slight adjustment can help – sometimes you need to shift or retension the spring holder in the plastic. Be careful not to damage any plastic parts.
If you have more details about the exact door or hinge models installed (e.g., soft-close hinges or standard), I can provide more specific help. Also: What exactly does the damage look like? Is the spring visibly damaged or just weak to the touch?
kulau schrieb:
Regarding the installation: You need to remove the door, which can be done either by loosening the hinge screws or by unlocking the hinges using a specific release mechanism.This is an important tip. I would add that with Metod hinges, there is usually a release mechanism that allows you to take the door off without having to remove screws. A slight press on the small lever under the hinge can release the spring tension and the door can then be lifted off.
It is also important during reinstallation to ensure the spring is positioned correctly; otherwise, the hinge functions will not work as intended. I also recommend wearing safety glasses, as springs can snap open suddenly.
If the door spring is completely broken, I have occasionally been able to get new hinge sets directly from Ikea, but the model must match exactly. The issue with individual spring replacement parts is that Ikea does not typically offer spare parts in the classic sense, often only complete hinge sets.
To conclude: Sometimes the spring is adjusted too much. If it is damaged, only replacement helps – otherwise, it is better to fine-tune or check if the door is hanging correctly.
I can totally understand that the issue with the door spring is frustrating, especially when there’s no clear instruction and the problem isn’t easy to pinpoint.
In my own experience, sometimes it’s the small things: dust or debris inside the spring mechanism can easily cause the spring to lose its function. So if anyone reads this post, I would recommend checking simple things like cleaning and lubricating before ordering expensive replacement parts.
I think it’s also important to have the confidence to carefully approach the mechanism – sometimes a small adjustment is enough to feel the spring snapping back again.
If anyone is nervous about removing parts: keep in mind that Ikea furniture is usually modular and nothing is irreparable. That gives peace of mind, even if the repair takes a bit longer.
I hope these thoughts help a bit and that the door will close reliably again soon!
lyndon schrieb:that’s a helpful tip because it can save a lot of time and hassle.
If the door spring is completely faulty, I have occasionally been able to get new hinge sets directly from Ikea
kulau schrieb:
If the spring is just loose, a slight adjustment can help
