ᐅ How can I readjust BILLY doors if they stick or don’t close properly?
Created on: 28 Jan 2021 07:13
gumonu
Hello everyone, I recently bought a Billy bookshelf and noticed that the doors do not close properly. They sometimes get stuck or are misaligned, especially at the top. I suspect the doors need to be readjusted. My question is: How can I correctly readjust the Billy doors if they stick or don’t close flush? Are there any special tricks or tools needed, and how can I ensure the doors stay properly aligned long-term? I look forward to any helpful advice!
I would like to go into a bit more detail—especially with Billy-style doors, you can work very precisely thanks to the three-way adjustability of the hinges.
There is a screw for vertical adjustment: you raise or lower the door to adjust the gap to the top edge. This screw is usually located at the top of the hinge, near the attachment to the cabinet frame.
Another screw controls the horizontal shift, meaning the sideways movement. Use this to correct if the door is hitting on one side.
The third screw regulates the depth, that is, how far the door protrudes into or out from the cabinet body.
Very important: If your doors stick particularly in one spot, this can also be caused by warped doors or screws that are tightened too much. Also check that the hinges are firmly attached and that no parts are loose.
One more tip: After adjusting, do not tighten the screws too much, as that can change the setting. Always test by opening and closing the door several times to ensure smooth operation.
I can completely understand how frustrating sticking doors can be! For me, it always helped to proceed step by step and finally check if adjusting the doors distributes their weight better and prevents the handles from catching. Sometimes, you only realize after a few days that a slight readjustment is needed. Keep at it; it's worth the effort!
Thank you all for the helpful advice! Yesterday, I tried adjusting the side alignment on the hinges using a Phillips screwdriver. This made the door run a bit better, but it’s still sticking slightly at the top. Should I also adjust the height screw there? And is there a risk that the door could warp too much if I turn it too far? By the way, I didn’t remove any covers – is that necessary, or can the screws be accessed easily as they are?
gumonu schrieb:
Should I also adjust the height screw? Yes, that’s exactly right. The height adjustment is responsible for preventing the door from sticking at the top. It’s best to open the door and turn the screw only slightly, about a quarter turn, then test it.
Regarding your question about the covers: The trim pieces can usually be removed; they cover the screws on the hinge. You should take them off for adjustment because the screws are otherwise hard to reach. Be careful when removing them—they don’t come off easily but are not glued on, just clipped in place.
Concerning the risk of distortion: As long as you turn the screws gently and carefully, nothing will happen. Turning too much or using force can damage the hinges, so proceed slowly and step by step.
I confirm that gently turning the height adjustment screw in small increments is the most effective method when the door sticks at the top.
It is also important to focus on one hinge point and not adjust all screws at once. A common mistake is turning too many screws simultaneously, which makes fine-tuning more difficult.
