ᐅ How can I quickly modify Ikea Metod cabinets during renovations?
Created on: 18 Sep 2015 08:47
mersimel
mersimel
18 Sep 2015 08:47
Hello everyone, I am currently facing the challenge of quickly and as simply as possible adapting our existing Ikea Metod kitchen cabinet system to new room dimensions and conditions during a renovation. Specifically, I want to know how to efficiently redesign the existing cabinet system without having to buy completely new cabinets or carry out extensive modifications each time. What tips or techniques do you have for adjusting Metod cabinets in a time- and cost-effective way during renovations? Practical advice and common pitfalls would be greatly appreciated. Thanks in advance!
Kugau
18 Sep 2015 09:13
Hello mersimel, very good and precise question! In my experience, when modifying Ikea Metod cabinets during renovations, it is advisable to first carefully measure and document the existing modules so you know what can be changed without much effort. In general, I would recommend:
- Use modular filler pieces or panels to cover gaps or inaccurate measurements.
- Don’t hesitate to trim cabinet boxes afterwards with simple tools like a jigsaw or multitool if the dimensions don’t fit exactly. This is usually faster than buying new ones.
- Make sure to keep the existing handles and hinges so the modifications remain visually consistent.
- In special cases, flexible shelves can also help optimize storage space.
By the way, I recommend using the Ikea planning software (Metod Planner) during the planning phase to quickly test different variations.
FABIAN_DEO
18 Sep 2015 10:22
Hello, I would like to delve deeper into the technical aspects of your issue, as I have extensive experience working with the Metod system. When quickly adapting Metod cabinets during renovations, you should consider the following points:
- First, precise measurement of the room is essential, including wall straightness and floor unevenness. These are common sources of errors that can complicate later installation.
- If the standard size does not fit, filler panels (e.g., Ikea filler panels) that can be cut to size are helpful. This is the best option for a quick modification, as it avoids costly new purchases.
- If you want to push cabinets together or change the layout grid, the connecting elements (e.g., dowels and metal braces) must be adjusted accordingly. I recommend always filling screw holes with wood filler and pre-drilling new holes beforehand to ensure stability.
- A professional sequence for the modification would be:
1. Removing the fronts to protect them
2. Adjusting and shortening the carcasses
3. Installing filler panels and trims
4. Reattaching the fronts and adjusting the hinges for a perfect fit.
- There are also special adapters from third-party suppliers that can make installation easier, for example with non-rectangular walls.
I would be interested to know more about the type of renovation. Are cabinets being relocated, or does the system need to be rescaled? This information helps provide more targeted advice.
mersimel
19 Sep 2015 07:55
FABIAN_DEO schrieb:
I would be interested to know exactly what type of renovation it involves. Are the cabinets being rearranged, or does the system need to be resized? That helps with more targeted advice.
Hello Fabian, thank you for your detailed post! This is a complete kitchen renovation where the cabinets need to be partly rearranged, so it involves both repositioning and partially reconfiguring the modules. The room layout is not rectangular, which adds an extra challenge. My goal is to avoid replacing too many components entirely and instead achieve the new dimensions with minor modifications and possibly filler panels. Some corners are slightly angled, and I am particularly concerned about adjusting the doors and hinges so that the appearance stays clean and precise.
V
vinli
19 Sep 2015 09:04
For efficient adjustment of Ikea Metod cabinets during renovations with irregular room dimensions, I recommend the following approach:
- Use flexible filler pieces made of MDF or particleboard, which you can cut precisely. This is cost-effective and quick.
- Use the standard Metod grid of 20 cm (8 inches) width as a base to connect compatible modules. This facilitates reuse.
- For angled corners, I suggest corner panels that you can shape with fine sandpaper.
- Doors and hinges: Carefully adjust the rotation angles and gaps using the screw mechanisms to ensure a neat appearance despite dimensional adaptations.
- If walls are not perpendicular, wooden strips can be used as shims to align the cabinets flush.
These methods are proven in practice and improve efficient implementation during renovations.
kyledeo
19 Sep 2015 12:37
I would recommend simply trying to use filler panels for Metod cabinets and, if necessary, trimming the carcasses slightly with a multi-tool. You can adjust the doors to ensure they close properly. Cover panels work very well for sloping walls.
