ᐅ How can I protect Malm furniture with waterproof varnish?
Created on: 19 Jan 2015 10:13
O
oskarmar
O
oskarmar
19 Jan 2015 10:13
I am looking for an effective way to protect my IKEA Malm furniture with a waterproof varnish. So far, the furniture is only varnished or veneered, but it is being used in the kitchen and other areas prone to moisture.
My main questions are:
- Which waterproof varnish is best suited for wooden furniture like Malm, which is mostly made of particleboard with a foil finish?
- How should I ideally prepare the surface to ensure good adhesion and durability of the coating?
- Are there any special tips for application (e.g., brush versus spray) or drying time that I should consider?
It would be great if someone with experience or expert knowledge could help, so I don’t end up with peeling spots or unpleasant discoloration later on. Thanks in advance!
V
vinli
19 Jan 2015 11:37
Regarding the question about the suitable waterproof varnish for IKEA Malm furniture, it is important to know that these pieces are usually made of cement-bonded particleboard with a foil coating.
A traditional clear wood-based varnish will often have adhesion problems here. Therefore, I recommend using a 2-component PU varnish or a special acrylic varnish designed for plastic surfaces.
Preparation:
First, lightly sand the surface without completely removing the foil. Then thoroughly remove dust and grease, for example, using denatured alcohol.
Application:
Spraying ensures an even coating, while brushing can appear uneven. It is important to apply several thin layers with drying time in between, about 2 hours per layer at room temperature.
This results in a durable, waterproof surface with good adhesion.
Annedeo
20 Jan 2015 09:26
Hello oskarmar,
especially with furniture like Malm, which is often covered with foil, surface preparation is crucial. If the foil is too smooth or glossy, paint adheres poorly. I recommend lightly sanding the surface first with 220-grit or finer sandpaper. Be careful not to sand too much to avoid damaging the foil.
When choosing paint, a water-based 2K acrylic or polyurethane paint is really ideal. These paints are not only waterproof but also low in toxins and more environmentally friendly than solvent-based paints.
For application, it’s best to use a fine paintbrush or a white foam roller to avoid brush marks. Alternatively, spray cans are an option—for example, products specifically designed for plastic surfaces.
Important:
Allow each coat to dry thoroughly (at least 12 hours) before applying the next one to ensure the full protective film is durable.
bareynaldo
21 Jan 2015 14:52
vinli schrieb:
I therefore recommend using a 2-component PU varnish or a special acrylic varnish for plastic surfaces.
Sure, professionals use 2K varnishes, which is fine – but honestly, who wants to do that at home? They are expensive, have a strong odor, and are not easy to apply.
I recommend something more everyday: a high-quality, water-resistant acrylic varnish from a hardware store, for example from Remmers or a similar manufacturer. This can also achieve good results without complicated equipment. The key is "patience" and thorough sanding.
Annedeo schrieb:
After painting, let each coat dry properly (at least 12 hours)
I completely agree. Even more important: anyone who thinks they can do this "quickly" will be disappointed sooner or later.
In summary: There is no single "best" method, but rather the one you can carefully prepare and carry out calmly. That way, the water-based varnish will also be durable on the Malm surface.
