Hello everyone, I have a problem that I would like to solve: How can I effectively protect IKEA Malm furniture from moisture to prevent swelling or mold? Unfortunately, my apartment is quite damp, especially in the rooms where I have the Malm dressers. I am looking for simple but effective methods that are also long-lasting. Are there any special sealants, impregnations, or other practical measures I can use without affecting the appearance or functionality of the furniture? Just keeping it dry is not enough for me. I look forward to helpful tips and experiences!
posin50 schrieb:
Apply a thin layer of clear varnish or wood oil! That really protectsThat is exactly a good idea. Clear varnish is versatile and effectively prevents moisture.
edisondan schrieb:
Rubber pads or felt glides are glued under the legs to prevent contact with moisture on the floorExactly! I did that, and since then, no more problems have occurred! 🙂
Thanks for all the helpful tips so far! I have one more question: How exactly do clear coats work? I want it to be as transparent as possible and with minimal gloss. Are there products specifically suitable for MDF from Malm? And how many coats would you recommend to ensure good protection? I definitely want to avoid any discoloration or unpleasant odor on the surface.
edisondan7 May 2020 09:08zarnon schrieb:
Are there products specifically suitable for Malm MDF? And how many coats would you recommend?For MDF, I recommend a water-based, matte clear coat without solvents. It dries quickly, does not discolor, and has minimal odor. Applying 2-3 thin coats is ideal, as this creates an even protective layer. Light sanding between coats with fine-grit sandpaper improves adhesion. It is important to let each coat dry thoroughly.
