Hello everyone, some time ago I bought a Malm bed from IKEA and am now using it in a bedroom that unfortunately isn’t well protected against moisture. My question is: how can Malm beds be protected from moisture to prevent damage such as swelling, warping, or mold growth? I understand that it is made of engineered wood, which is particularly sensitive. Are there specific sealants or protective treatments that work effectively, or is it better to focus on improved air circulation and climate control in the room? I look forward to your informed tips and recommendations, including any personal experiences.
cassandra19 May 2022 14:27As an additional note: Malm beds are made from MDF or chipboard panels coated with melamine resin, which is not completely waterproof. The vulnerable points are the cut edges, where moisture can penetrate especially quickly. From a technical perspective, I recommend lightly sanding these edges with fine sandpaper and then applying a special polyurethane-based edge sealer. This provides long-lasting protection against moisture ingress. It is also important to maintain the right indoor climate, ideally between 18-22°C (64-72°F) with 40-60% relative humidity. A dehumidifier can be essential if humidity remains high over time.
Hector schrieb:
Do you have the possibility to keep the indoor humidity consistently between 40-60%? The indoor humidity unfortunately fluctuates quite often, but I make sure to ventilate regularly, especially in the mornings and evenings. I haven’t used a dehumidifier so far, but that might be an option.
cassandra schrieb:
Applying edge sealers based on polyurethane That sounds interesting. Do you have any recommendations for specific products or suppliers? I would prefer not to experiment randomly and risk damaging the bed with the wrong materials.
aaronleo schrieb:
I would be reluctant to experiment randomly and ruin the bed with the wrong products.Here is a provocative question: Should we not simply accept that furniture in this price range is generally not a long-term solution if the living environment is less than ideal? Investments in expensive protective treatments often cannot compensate for unfavorable placement conditions. Sometimes rethinking space usage or furniture choices is more sustainable than constant repairs.
ANMARCOS schrieb:
Sometimes rethinking space usage or furniture choices is more sustainable than constant repairs. I agree. One alternative: replace Malm with a wooden piece made from solid wood. These usually provide more durable moisture protection, although they tend to be more expensive. If you want to stick with Malm’s design and price, the focus for moisture resistance should be on the room and climate conditions, not on the furniture’s surface treatment.
