ᐅ How can I protect Malm beds from moisture?
Created on: 19 May 2022 08:23
aaronleo
aaronleo
19 May 2022 08:23
Hello everyone, some time ago I bought a Malm bed from IKEA and am now using it in a bedroom that unfortunately isn’t well protected against moisture. My question is: how can Malm beds be protected from moisture to prevent damage such as swelling, warping, or mold growth? I understand that it is made of engineered wood, which is particularly sensitive. Are there specific sealants or protective treatments that work effectively, or is it better to focus on improved air circulation and climate control in the room? I look forward to your informed tips and recommendations, including any personal experiences.
Hector
19 May 2022 09:11
aaronleo schrieb:
How can I protect Malm beds from moisture to prevent damage like swelling, warping, or mold growth?
First of all: Malm beds are made from particleboard with a decorative foil, which is naturally very sensitive to moisture. The question is whether it might be better to address the surrounding environment. A sealant can improve protection, but moisture often penetrates through the edges, which are rarely well sealed. Do you have the ability to maintain the indoor humidity consistently between 40-60%? Because this is proven to be the best protection against mold and swelling in wood-based materials. Additionally, placing an underlay beneath the bed could help avoid direct contact with residual moisture from the floor. What have you tried so far?
Santi
19 May 2022 09:45
I would seal the edges with a clear sealant (such as acrylic sealant). Additionally, you can treat the bed with furniture wax or a wood protective oil, but only on untreated areas. It is important to keep the room well ventilated and to avoid moisture directly on the bed.
Emery
19 May 2022 10:32
A proven method is to treat the back and especially the visible edges with a moisture-resistant wood varnish. This creates a barrier against rising damp. It is also advisable to regularly monitor the indoor humidity with a hygrometer to take early countermeasures. Additionally, the bed and slatted frame should not be placed directly on a cold floor to prevent condensation.
Hector
19 May 2022 11:07
Santi schrieb:
I would seal the edges with a clear sealant (such as acrylic caulk).
Interesting suggestion, but is that durable in the long term? Acrylic caulk often remains flexible and can crack when the bed moves. Perhaps an epoxy-based edge protection would be better, even though it is more complex to apply.
That certainly makes sense, but the type of material should be checked beforehand, as chipboard reacts differently to varnishes. This could cause stress or warping.
notupra
19 May 2022 11:35
Place the bed at a distance from damp walls. A moisture barrier under the legs or small plastic pads can help. Otherwise, regular ventilation and keeping the walls dry are often the only solutions.
