ᐅ How can I reduce the wobbling of the Malm bed?
Created on: 7 Oct 2016 08:43
Lupopra
Lupopra
7 Oct 2016 08:43
Hello everyone, I have a problem with my Malm bed from Ikea – it wobbles quite a bit when moving or getting up. This is not only annoying, but I’m also concerned about the long-term stability. I have already checked that all screws are properly tightened, but that hasn’t made any noticeable improvement. Does anyone have experience with reducing the wobbling in a Malm bed? Are there any special tips or accessories that can help make the structure more stable? I would appreciate any helpful ideas, as I would like to sleep without the distracting wobbling.
Fareo65
7 Oct 2016 09:12
Lupopra schrieb:
Are there any special tips or accessories suitable for making the construction more stable?
First of all, I recommend a thorough check of all fasteners, such as screws and dowels. With the Malm bed, it is especially important that the central support beam as well as the headboard and footboard are firmly connected. If wobbling persists despite tightened screws, additional metal brackets can be used to reinforce the corners. Alternatively, some users suggest self-adhesive felt pads or furniture stoppers for the floor to minimize slipping, which indirectly reduces wobbling.
mifra
7 Oct 2016 09:57
In addition to Fareo65’s points, I would like to address the issue of the slatted bed base insert. Often, the slatted frame is not firmly secured or becomes slightly misaligned, which can significantly affect stability. It is worth checking the slatted frame and possibly securing it with stronger screws or additional brackets. Retightening the screws on the slatted frame itself can also noticeably improve stability. For sagging slatted frames, the only solution is replacing it or using a firmer model.
blaki
7 Oct 2016 11:03
I always find it funny how much force you can generate when the bed wobbles – more of a workout than some exercise machines 😄 But seriously, if all the screws are tight and the bed still wobbles, using rubber or felt pads under the bed legs often helps. This compensates for uneven floors, making the bed much more stable. Plus, it’s an affordable solution if you’re not keen on DIY.
rotofra
7 Oct 2016 13:21
For a clear approach to reducing wobbling, I recommend the following systematic steps:
1. First, check all screws and connections and tighten them as needed. Be careful not to overtighten.
2. Check whether the center support beam of the bed is still correctly positioned – it can sometimes shift slightly.
3. For wooden joints, a minimal amount of additional glue can help if the screws no longer hold.
4. Secure appropriate metal angle brackets at critical connection points if the frame has any play.
5. Ensure the floor is level. Small unevenness can be compensated with spacer pieces made of wood or plastic.
Working through these points usually leads to a significant improvement.
gaubla
7 Oct 2016 15:02
I agree with this and would like to add that inspecting screws for damage is also important. Sometimes the threads are worn out, which compromises stability. In such cases, the screws need to be replaced or repaired using wood filler to create new threads. Using thread-locking adhesive can also help prevent the screws from loosening again.
