Hello everyone, I have a problem with my Malm bed from Ikea – it wobbles quite a bit when moving or getting up. This is not only annoying, but I’m also concerned about the long-term stability. I have already checked that all screws are properly tightened, but that hasn’t made any noticeable improvement. Does anyone have experience with reducing the wobbling in a Malm bed? Are there any special tips or accessories that can help make the structure more stable? I would appreciate any helpful ideas, as I would like to sleep without the distracting wobbling.
At this point, I would like to question whether the flooring and the surrounding room conditions were sufficiently considered when assessing the wobbling. A very smooth floor or different flooring materials can easily cause the bed to wobble. It might also be worth checking if the issue is due to the bed size or uneven weight distribution. Sometimes we think there is a structural problem when, in fact, the physical conditions are the decisive factor.
Natan schrieb:
Whether the flooring and room environment have been sufficiently considered.This is a valid point. Different types of flooring, whether laminate, carpet, or tile, affect the stability of furniture. Especially on smooth floors, it is advisable to use non-slip rubber pads under the bed legs. These prevent sliding and thereby reduce the perceived wobbling. Additionally, depending on the flooring, a small leveling pad can be used to compensate for minor unevenness.
Here is a brief summary in the form of a small "repair guide for a wobbly Malm bed":
- Step 1: Loosen all screws and retighten them with the correct torque
- Step 2: Add metal brackets at the connection points
- Step 3: Attach rubber pads under all feet
- Step 4: Check the slatted frame for a secure fit and, if necessary, additionally screw it in place
Common mistakes:
- Over-tightening screws, which damages the material
- Not compensating for uneven floors
- Slatted frame wobbles without it being immediately noticeable
This way you can proceed systematically and cover the most frequent causes.
Common mistakes:
Wow, these are really great tips here! I just want to add that it’s fantastic you’re not only focusing on the screws but also considering the floor and slatted frame. I once had a bed that wobbled like crazy – and it was really the rubber pads that made a huge difference instantly! So: Go for it, it’s definitely worth it 🙂 Good luck!
Thank you very much for all the detailed answers and tips! I will work through the points one by one, especially since I hadn’t considered the metal brackets so far. The note about the rubber pads and uneven floors also sounds very plausible, as I actually have laminate flooring that is slightly uneven in places.
If I have any more questions, I’ll get back in touch, but for now I will continue focusing on the screws, the slatted frame, and improving floor grip. Thanks again to everyone who shared their experience and knowledge – very helpful!
