ᐅ IKEA MALM bed still squeaks after cleaning – what to do now?
Created on: 16 Jul 2018 08:43
Julia-do
Hello everyone, I have an IKEA Malm bed that continues to squeak despite cleaning. I have checked all the joints, tightened all the screws, cleaned the metal rails, and even tried light lubricants. However, the squeaking persists, especially when moving or putting weight on the bed. Has anyone had similar experiences or tips on how to permanently eliminate the noise? I would prefer not to buy new parts or completely disassemble the bed unless absolutely necessary.
Natan
16 Jul 2018 13:46
edisondan schrieb:
Use graphite powder for lubrication, as it doesn’t stick and reduces friction over time.
That sounds reasonable, but do you have a source for that? I’m asking because some forums recommend other substances, and I’m skeptical whether graphite powder might leave marks or cause damage in the long run.
edisondan
16 Jul 2018 14:04
Regarding Natan’s question: Graphite powder is widely used as a dry lubricant in many technical applications, such as hinges and locks. It does not stick, attract dust, or leave wet residues.
IKEA itself or official repair guides usually recommend silicone sprays over oils, which can be wet. Although graphite is not explicitly mentioned by IKEA, it is recognized in professional literature on furniture joints as a suitable lubricant.
When applied carefully to the contact points of the Malm bed, I consider it to be safe.
Natan
16 Jul 2018 14:18
Thank you for the explanation. This at least allows for a logical assessment of the lubrication issue with the MALM bed. In my opinion, it is also worth considering whether the problematic squeaking might stem from a structural weakness, such as poor wood quality or imprecise drilling, which can only be fixed with makeshift solutions.
Julia-do
17 Jul 2018 07:52
Thank you all for the helpful advice! Today, I will carefully loosen the screws again, clean the areas, and then treat them with graphite powder. I will also get felt strips to place under potential friction points.
One more question: Is it possible that, despite all measures, the wood changes due to moisture or temperature, affecting the squeaking? I live in an apartment with relatively high humidity.
sarlo
17 Jul 2018 08:27
Julia-do schrieb:
that despite all measures, the wood is affected by moisture or temperature
Yes, that can definitely happen. Wood is a natural material that moves and changes its dimensions due to fluctuations in humidity – this can affect the fit and cause noises.
One tip: try to protect the bed from sources of moisture as much as possible and ventilate regularly. Wood can also swell or shrink slightly, which impacts the joinery.
klabe
17 Jul 2018 09:11
Additionally:
Wood does not only react to moisture; temperature fluctuations also cause slight expansions and contractions. It is advisable not to tighten screws completely “tight” but rather with an awareness of the wood’s natural movement. In MALM beds, overly rigid connections can quickly lead to creaking or squeaking.
Furthermore, hardly visible spacers (e.g., felt or rubber) factory-installed on the metal supports help to decouple the materials and reduce noise.
For those technically inclined, lightly rubbing the metal supports with candle wax is another trick to reduce friction on hard surfaces.
