ᐅ How can you find replacement screws for Malm furniture?
Created on: 24 Dec 2019 10:07
Nebau32
Nebau32
24 Dec 2019 10:07
I recently noticed that some screws are missing or have been lost from my Ikea Malm bed. Now I am facing the challenge of finding suitable replacement screws that fit perfectly to ensure the bed’s stability and safety. My question is: What is the best way to find replacement screws for an Ikea Malm bed?
I’m mainly interested in the exact specifications: What thread size, length, and type of screws do the furniture manufacturers use for Malm? Are there reliable sources where these screws are available in the same quality, or is it better to order spare parts directly from Ikea?
I would appreciate hearing about your experiences on how to best identify and obtain these screws. Thanks in advance!
Rashadmeo
24 Dec 2019 10:15
Hey! It’s great that you’re reaching out directly to the community! I had the exact same problem with my Malm table, and what I found is that it really helps to measure the screws precisely – ideally with a caliper, so you know the thread type and length exactly!
There are also excellent online stores for furniture fittings where you can find almost all common screws. And of course, Ikea itself offers spare parts, but that sometimes takes a while and isn’t always cost-effective. In the end, I found my screws at a small specialist screw shop that gave me really good advice. 🙂
Don’t give up – eventually, you’ll find the perfect screws!
KAMERON
24 Dec 2019 10:43
Additional information: The Ikea Malm bed typically uses screws with M6 metric threads for assembly. The length varies depending on the connection point—usually between 50 and 70 mm (2 and 2¾ inches). The exact size can be found in the Ikea assembly instructions or directly checked in Ikea’s spare parts shop.
A precise approach:
1. Measure the screw (diameter, length).
2. Confirm the thread type (usually metric).
3. Search for spare parts through Ikea or specialized screw suppliers offering furniture screws.
Buying directly from Ikea is reliable but not always the best option due to delivery times and cost. Hardware stores specializing in screws often provide more affordable alternatives. However, attention must be paid to the strength class (at least 8.8) to ensure structural safety.
GiRoyce
24 Dec 2019 11:02
I would like to add some basic information that is especially important for furniture like the Malm:
The screws Ikea uses are not regular hardware store screws. They are often specially coated to prevent rust and to avoid damaging the wood.
From my experience, when replacing them, it is important to pay close attention to these details: the thread must match exactly (metric M6 is correct, but Ikea sometimes differs slightly), and ideally you should have a suitable screw head, such as an internal hex (Allen) that fits well.
Alternatively, you can try contacting Ikea customer service – they often provide replacement parts for free or for a small fee.
It is important not to use screws that are too long or too thick to avoid damaging the furniture.
retau
24 Dec 2019 11:55
Hello! What an interesting question! 🙂
I also disassembled my Malm bed once and had the same problem: Where can I get replacement screws? My tip: Ikea actually has a spare parts program on their website! They call it "Parts & Accessories" – there you can enter the model number and usually order the matching screws.
Sometimes they are a bit more expensive than at a hardware store, but the fit is definitely accurate! My advice: Besides ordering from Ikea, be sure to visit the local screw section with a measured sample to look for comparable screws.
Then you can decide based on the price which option suits you better. Good luck with your search!
Svenja7
24 Dec 2019 12:27
I'll join the conversation too – maybe this helps:
You should carefully check the assembly instructions or any PDFs available online. Ikea sometimes specifies exact screw types there, making it easier to buy the correct replacements.
If you already have the screws, I strongly recommend measuring them precisely before ordering (length, diameter, thread type) and, if necessary, comparing them with samples at a local hardware store.
If you do everything correctly, you can also contact Ikea customer service – some people report that you can even receive complete replacement sets if you provide the correct model code.
In short: Try to use Ikea’s resources first, then a hardware specialist, before resorting to screws that might not be suitable.
