I am currently looking into the topic of "How to prevent warping in Malm beds?" and would like to start a comprehensive discussion here.
My main focus is on understanding the exact causes of typical deformations in this bed and which measures—both in handling, maintenance, and possibly modifications—are effective in extending its lifespan and ensuring long-term stability.
At home, I have already noticed slight warping in the wood, and I want to avoid it getting worse.
What are your experiences, tips, or materials that are particularly suitable for maintaining stability? Do these recommendations apply to the classic Malm bed construction with particleboard, or are there differences with other versions, such as a solid wood model?
I look forward to your insights and practical advice!
Kolepau schrieb:
the main causes of deformation are usually moisture and uneven loading.That may be true, but what about the sometimes low-quality materials? Malm is more of a mass-produced item, and I doubt the quality of the chipboard used is always high. Maybe the product is simply designed so cheaply that deformation is inevitable.
I often find the whole "care" debate a bit exaggerated. Why should I have to take care of something for months that should actually be durable? Isn’t that a design or quality issue?
rebufar schrieb:
Wasn’t that a design or quality flaw?The criticism is justified, but it is important to distinguish between product quality and usage conditions.
Particle boards are generally more sensitive to moisture than solid wood. This is a physical fact, not a manufacturing defect.
Anyone purchasing a bed made of particle boards must take these characteristics into account and apply appropriate protective measures.
LANICOLE schrieb:
Place the bed against a damp wall or directly on a damp floor.Thank you for the clear instructions, LANICOLE.
Could you please briefly explain the best way to measure humidity and, if necessary, how to control it?
I was thinking about buying a simple hygrometer, but I’m unsure if that’s enough or if it’s better to install a system directly.
Hello Knutpe,
regarding your question about measuring humidity:
1. Hygrometer
- A simple electronic hygrometer is perfectly adequate for most bedrooms.
- It is important to take measurements in several locations to detect variations in humidity.
2. Regulating humidity
- Fans or small dehumidifiers help with excessive humidity.
- Natural ventilation by regularly airing out the room throughout the day is very effective.
3. Installation of climate control systems
- Only necessary in exceptional cases, for example in extremely damp basements or very humid climates.
- For typical residential use, this is usually excessive.
Conclusion: A simple hygrometer combined with mindful ventilation is generally sufficient to protect your bed.
1. Hygrometer
Knutpe schrieb:
I was thinking about buying a simple hygrometer, but I’m not sure if that’s enough or if it’s better to install a full system right away.That’s absolutely enough!
I also just have a small, inexpensive hygrometer, and it works great. If the humidity rises, just open a window – and everything will be fine 🙂
No need to overcomplicate things, keep it simple – otherwise, maintenance won’t be enjoyable!
