ᐅ How can I protect Ikea PLATSA from moisture?
Created on: 8 Mar 2018 19:23
Ken-ni
I have a question regarding the protection of my Ikea Platsa system from moisture. I plan to place the furniture in a room that occasionally becomes a bit more humid—especially near a window that slightly condenses in winter and sometimes lets in moisture when ventilated in summer.
Since PLATSA is made of wood particleboard with a melamine coating, I’m concerned that moisture could damage or cause the material to swell over time. Are there proven methods to effectively protect the furniture from this kind of moisture?
I’m particularly interested in practical but also long-term solutions. Examples or tips on surface sealing, additional seals, suitable indoor climate measures, or other protective precautions would be very helpful.
I look forward to your experiences and assessments. Thanks in advance!
GIBAPO
9 Mar 2018 09:14
It is important to keep in mind that the melamine coating of Ikea Platsa is dirt- and water-repellent but not waterproof in a construction sense. Therefore, the following points are crucial for moisture protection:
- PLATSA should never be exposed to permanently humid environments,
- connection edges are weak points and must be sealed,
- a distance of at least 5 cm (2 inches) from windows and exterior walls is recommended,
- regular ventilation to prevent condensation,
- with increased humidity, using a hygrometer for monitoring is advisable.
Regarding edge lacquer: special furniture edge lacquers with high abrasion resistance and water resistance are absolutely necessary; general clear coats do not provide lasting protection.
Whether you apply the lacquer layers yourself or have a professional do it depends on your skills and available time.
Conclusion: Only through the right combination of measures — mechanical spacing, air climate control, and edge sealing — can PLATSA be effectively protected from moisture.
