ᐅ How can I prepare Ikea PLATSA furniture for outdoor use?
Created on: 14 Feb 2020 09:24
V
vinmeo
I am planning to use my IKEA Platsa furniture in the garden but want to prepare it properly so it doesn’t get damaged quickly by moisture, UV exposure, and other weather conditions. Since PLATSA is actually designed for indoor use, my question is: How can I best prepare IKEA PLATSA furniture for outdoor use to make it last longer?
What materials should I use to protect the surfaces? Is a simple water repellent treatment enough, or should I consider fully coating the furniture with a special varnish? Are there any experiences with combining PLATSA and outdoor furniture or tips on construction to avoid water pooling?
I would be very grateful for any practical advice, experiences, or recommendations on products and treatment methods!
naujon
16 Feb 2020 09:03
Here is a brief guide on how to prepare Platsa furniture for outdoor use with minimal risk:
1. Disassemble the furniture: This allows you to better treat all edges and hard-to-reach surfaces.
2. Sanding: Lightly sand the surface with fine sandpaper to improve adhesion.
3. Primer: Apply a suitable primer coat (e.g., a water-repellent wood preservative).
4. Protective coating: Apply at least two layers of a UV-resistant, water-repellent varnish.
5. Drying: Allow each layer to dry thoroughly between coats.
6. Assembly: Assemble the furniture in a dry location.
7. Placement: Raise the furniture on feet or small stilts to avoid water contact with the ground.
8. Location: Place the furniture in a shaded, wind-protected area whenever possible.
Following these steps gives you a realistic chance to protect PLATSA furniture for garden use. Regular maintenance is recommended.
bujufa
16 Feb 2020 16:48
Alina67 schrieb:
It is absolutely necessary to treat all edges and surfaces several times with a water-repellent wood protection oil or a high-quality polyurethane (PU) varnish.
I fully agree and would like to add: For outdoor use, a water-repellent finish that does not crack is essential.
Ideal are flexible two-component (2K) coatings that do not peel off with temperature changes. Sealing the edges with clear varnish before painting also increases durability.
Overall, using PLATSA in the garden always requires a certain level of protection and regular maintenance if you want to enjoy it for a long time.
