ᐅ How can I repaint or customize Ikea BRIMNES furniture myself?
Created on: 20 Jun 2019 08:37
U
UGURJA
U
UGURJA
20 Jun 2019 08:37
Hello everyone, I am considering repainting or redesigning my Ikea Brimnes furniture myself, as I no longer like the standard white look. My specific question is: What preparatory work is necessary on the BRIMNES furniture to achieve a painted surface that is durable and scratch-resistant? I have heard that the surface is not classic wood, but more like a foil – what is the best way to handle this? I am also interested in which paints or coatings work best for this, whether there are special primers needed, and if I require certain tools (sandpaper, spray cans, brushes, etc.). Additionally, it would be helpful if someone could share practical tips for creative redesigns beyond just painting, such as applying adhesive films or adding textures. I look forward to your experiences and advice!
Rashadmeo
20 Jun 2019 09:03
Hey UGURJA, great question! The BRIMNES furniture is often laminated, which makes painting a bit tricky. My advice: first, sand the surface well, preferably with fine-grit sandpaper (220 to 320 grit), to create a good base for adhesion. After that, you should definitely use a primer to prevent the paint from peeling off immediately. It’s best to use a primer specifically designed for plastic or laminated surfaces. I’ve had good results with spray primers because they provide an even coat.
UGURJA schrieb:
Welche Vorarbeiten sind bei den BRIMNES-Möbeln notwendig, um eine lackierte Oberfläche zu erzielen, die auch langlebig und kratzfest ist?
This really shows that preparation is everything! If you do it right, the paint will last forever. And if you feel like getting creative, try chalk paint or matte paint for a nice stylish vintage look. Just don’t give up if it’s not perfect at first—practice makes perfect! Good luck! 🙂
gasidney
20 Jun 2019 11:29
Simply sand down, then apply a plastic primer, followed by several thin coats of paint. Don’t forget to sand between coats. Done.
Raymond
21 Jun 2019 07:45
Hello UGURJA, I’d like to add some basic tips to get you started.
Since BRIMNES furniture is usually coated with melamine or a foil finish, the surface is very smooth and non-porous, which makes painting more difficult. You should mainly follow these steps:
- Lightly sand the surface using 320-grit sandpaper to remove the gloss and improve adhesion.
- Clean the surfaces thoroughly to remove any dust or grease.
- Use a special primer designed for smooth surfaces (for example, a plastic-based primer).
- After it dries, apply acrylic paint or furniture spray paint in several thin layers.
- Lightly sand between coats for a smooth finish.
For a long-lasting result, the primer is crucial; without it, the paint will peel off quickly.
For creative redesigns: applying high-quality self-adhesive foil or special wallpapers can also work, but the surface should be smoothed out and free of bubbles.
If you like, I can also give you tips on correct brush techniques or discuss sealing the finish.
Rashadmeo
21 Jun 2019 09:17
Raymond schrieb:
For a long-lasting result, priming is essential; without it, the paint will peel off quickly.
I completely agree! I once made the mistake of starting without priming, and after a few weeks, the paint peeled off completely. Oh, and another important tip: don’t apply the paint too thickly! It’s better to use many thin layers. If you want a special look, you can also decorate the furniture with stencils or wax crayons. It’s a lot of fun and creates a unique appearance! Just give it a try.
Keep at it — it’s definitely worth it!
edisondan
21 Jun 2019 11:42
In addition to the previous tips, here is a structured overview for painting and redesigning the BRIMNES furniture:
- Preparation:
- Disassemble the furniture if possible to access all surfaces.
- Roughen the surface using 220-320 grit sandpaper, focusing on a uniform matte finish.
- Clean thoroughly (dust, grease).
- Primer:
- Use an adhesion primer suitable for melamine or plastic surfaces.
- Apply at least 2 coats and allow to dry completely.
- Painting:
- Use acrylic paint or spray paint.
- Apply several thin coats, sanding between coats with 400 grit paper for smoothness.
- Protection:
- A clear coat (matte or satin) can improve durability as a sealant.
- Alternative design:
- Creative techniques like applying contact foil or stenciling are possible, but are mainly recommended for surfaces with low wear.
Recommendation: Use high-quality materials to ensure durability and appearance. For frequently used furniture, painting with a protective sealant is the best option.
