I want to optimize the furnishing of my small living space with IKEA Platsa furniture, but I find the planning a bit challenging. Iâm especially interested in how to combine the modules effectively to make the most of the available space without making it feel overcrowded. Are there proven strategies, for example, for choosing the right sizes, using vertical space, or incorporating hidden storage?
Also, Iâd like to know if there are specific elements that work particularly well for tight corners or sloped ceilings that I have in the room.
Does anyone have practical tips for planning and using the IKEA planning tools, or experience with clever solutions that make the space feel larger and more organized? Thanks in advance for your help!
The PLATSA series is very versatile. The key is to measure accurately and then stack the modules vertically to maximize storage space in height. Especially use the corner units to avoid wasting any space. Itâs better to avoid large doors and instead opt for drawers or open compartments. This way, everything feels airier.
Hello Reo10,
to plan PLATSA furniture effectively for small spaces, it is really helpful to first write down all the room measurements precisely â including radiators, windows, and sloped ceilings. Then you can use the IKEA planner, which allows you to virtually combine different modules.
An important tip: Often, choosing fewer but taller furniture pieces works better so that the space doesnât feel cluttered. Open shelves can also help create a lighter impression, while closed cabinets keep things organized.
If you have to deal with sloped ceilings, you can save space by using shorter modules there or even custom elements. Feel free to ask if you want more details about specific corners!
RABLA schrieb:Thatâs true, corner solutions are invaluable in small areas.
Make sure to use corner units especially, so you donât waste any space.
The problem with IKEA PLATSA is often that it is presented as a cure-all for small spaces, even though it actually offers few truly innovative solutions. Why not simply use multifunctional furniture instead of relying rigidly on individual modules?
Personally, I think people should experiment more rather than just building on predefined systems â the PLATSA series is flexible, but its fixed dimensions often make planning tricky.
Julien schrieb:I consider this a nearly dogmatic view. In some small rooms, it can even be better to arrange shallower furniture in several groups, as this allows for more flexibility and prevents the space from feeling quickly overloaded.
Itâs often better to choose fewer but taller pieces of furniture so the room doesnât feel cluttered.
Hello everyone, I would like to suggest a structured approach for planning PLATSA furniture for small spaces:
- First, take precise room measurements, including door swings and any sloped ceilings.
- Create a sketch and define the primary storage needs (clothing, books, other items).
- Use the IKEA PLATSA planner to virtually test different combinations in advance.
- Focus on vertical space utilization, preferably stacking units instead of only planning based on floor area.
- Use corner modules strategically â they save space and provide more storage.
- Choose a mix of open and closed elements to avoid the overall look from becoming too heavy.
- If possible, play with light colors and mirrors to visually enlarge the space.
Typical mistakes include choosing cabinet units that are too large or having too many heavy fronts that overwhelm the room.
If the ceiling height is limited, I recommend narrower widths and many top panels to create order inside.
If needed, I can also outline a detailed step-by-step plan here.
