ᐅ How can I modify the Ikea Besta modular system for changing uses?
Created on: 12 Dec 2022 08:12
CORNELIA63
Hello everyone, I purchased the Ikea Besta system for my living room to make it as flexible as possible for changing uses. Specifically, I want to modify the shelving unit so that I can use open shelves, closed cabinets, drawers, or a combination of these depending on my needs—possibly also including components for media storage or space for work materials. It is important to me that the modification is modular and doesn’t require major carpentry work, so I can easily change the configuration over time. Are there any practical tips, recommendations for additional components, or modifications you know of for a flexible conversion of the Besta system? Thanks in advance!
Good question, Cornelia! The Besta modules are generally well-built but mainly use dowels and screws for connections. Frequent disassembly and reassembly of dowels often leads to material wear and less stable joints.
My advice:
- Additionally, use small metal brackets or screw connections that can be easily loosened.
- Use quick-release fasteners or clip connectors designed specifically for modular furniture.
- If possible, use clamps during assembly to hold the modules firmly together.
This way, you can reduce wear while maintaining flexibility.
My advice:
CORNELIA6313 Dec 2022 07:53I would like to add that I am particularly planning a combination of open compartments for books and drawer units for loose items, which I want to vary depending on the season or usage. Does anyone know how the different fronts (wood, glass, metal finish) affect modularity and ease of use?
The choice of front panels does actually affect usability. Glass fronts look elegant but are somewhat heavier and more delicate, especially with frequent remodeling. They are less easy to install in different locations because the door hinges are usually fixed. Metal-effect fronts are more durable and resistant but do not fit every interior design. Wooden doors, on the other hand, are flexible and can usually be painted or repainted more easily if your needs change.
I recommend soft-close hinges and replaceable handles for frequent remodeling to quickly adapt the appearance.
Timmyse3613 Dec 2022 09:45klo61 schrieb:
The choice of fronts really does affect usability. That’s true, especially if you change the setup frequently, it can be stressful. What helps me is to clearly decide beforehand which configuration I need and for how long. This way, I avoid unnecessary adjustments and can commit to a stable solution. Still, I think it’s great that Besta offers such flexibility.
SauDietmar14 Dec 2022 08:21Here are a few more tips that can be helpful if you plan to carry out many remodeling tasks:
- Label your modules and shelves so you can quickly identify and reassemble the parts correctly.
- Use universal connectors that work for both wood and glass fronts.
- Keep symmetry in mind during planning to ensure the modules can be combined in various ways.
- Also consider the back panels: removable or rotating back panels can often be very useful.
All of this increases modularity and helps prevent frustrating installation errors.
