ᐅ How can I combine Ikea Besta units with wooden fronts to create a natural look?
Created on: 9 Aug 2021 07:23
pikoge
I’m planning to redesign my living room and want to combine Ikea Besta cabinets with wooden fronts to create a natural and warm atmosphere. Since Besta offers a very flexible basic structure with simple fronts, I’m especially interested in which types of wood and finishes work best to achieve a harmonious, nature-inspired look.
What I would like to know:
- Which types of wood (oak, birch, walnut, etc.) work well with Besta dimensions and appear authentic?
- Do you have tips on surface treatments (oiled, waxed, lacquered) that keep the wooden fronts durable while maintaining a natural appearance?
- Are there experiences with combining lacquered Besta carcasses in white or anthracite with wooden fronts?
- How can transitions or joints between wooden fronts be finished cleanly?
I’m looking forward to all your experiences, tips, or even critical feedback on how to best implement this so that the overall look is cohesive. Thanks in advance!
pikoge
9 Aug 2021 14:33
Thanks for the initial tips!
I'm especially interested in the type of edge banding you chose. Should it be the same wood, or is it better to go for something more subtle?
Also, I'm wondering if oiled fronts combined with a white carcass might be counterproductive if the wood looks too warm. Does anyone have examples or experience on how to achieve a harmonious mix?
And one more practical question: How did you attach the wooden fronts to the Besta carcasses? IKEA doesn’t offer pre-drilled holes for different fronts, right, or did you use custom solutions?
gesar32
9 Aug 2021 15:02
For installation:
Many use adapters or special mounting brackets for wooden fronts, which are available as separate kits. Alternatively, some hinges are compatible with mounting plates to attach fronts.
Edge bands should ideally be made from the same wood to make joints visually less noticeable.
Regarding color combinations: A white matte cabinet body pairs excellently with oiled oak wood, creating a fresh, natural look. The white tends to balance out warmer wood tones rather than emphasizing them.
Ianlau
9 Aug 2021 15:56
I combined Besta with birch wood fronts and treated them with a natural oil. The finish is relatively light and creates a warm atmosphere.
For mounting, I had wooden panels cut to size and then attached them using special clips from IKEA. The fronts were pre-drilled to fit the hinges.
Accurate measuring and careful adjustment are important to ensure nothing sticks or gets jammed.
TAUPLO
9 Aug 2021 18:47
Hello everyone!
I love the combination of white and wood with a special touch. Oiled wood is great if you don’t mind occasional maintenance. For the transition, wooden strips or perhaps even narrow brass strips could work if you want a slightly more elegant look.
JONKO schrieb:
I have the cabinet in white and find the contrast perfect.
I can only agree with that.
Here’s a tip: If the wood tone is a bit too warm, you can neutralize it with a slightly gray wax, which makes it much more subtle without losing its natural character.
bente
10 Aug 2021 07:01
Good morning!
I agree with the others, especially regarding the edge strips. I used the same wood for the trim, and for me, it looked very harmonious. The transitions are barely noticeable.
pikoge schrieb:
Does anyone have an example or perhaps experience on how to achieve such a harmonious mix?
Something that can also help is choosing floor decoration or the sofa in a similar wood tone. This way, the overall look comes together, and the white body doesn’t appear as harsh.
pikoge
10 Aug 2021 10:26
Great, thanks for the detailed explanations!
Regarding attachment methods: I will look into adapter plates and special clips, that sounds feasible.
So far, I’m also leaning toward oiled oak with a white carcass. I’m now more confident that this contrast can be well balanced. I plan to have the panels custom-made and then work with matching edge trims.
Is anyone working on similar projects or maybe has tips on maintenance? How often should oiled surfaces be refreshed, especially for frequently used living room furniture?
