ᐅ How can I make MALM furniture weather-resistant?
Created on: 19 Jan 2023 14:23
Leome8
Leome8
19 Jan 2023 14:23
I recently bought a Malm piece of furniture from IKEA and would like to use it outdoors, for example on the balcony or on a covered terrace. Unfortunately, these furniture items are originally not designed for outdoor use. My question is: How can I make Malm furniture weatherproof?
I am especially interested in which materials or treatments are best suited to protect the wood from moisture, UV rays, and temperature fluctuations without significantly affecting the appearance and functionality. Ideally, it should be a solution that lasts long-term and is not too complicated to apply.
I look forward to your advice, especially if you have practical experience or product recommendations!
SONLIS
19 Jan 2023 16:48
That is a very valid question, as MALM furniture is usually made from melamine-coated particleboard, which is not really designed for outdoor use.
For weather resistance, I recommend a multi-step treatment: first, carefully sand the surface to improve adhesion of the protective layer. Then apply an oil-based product or a special exterior wood varnish.
It is important to mechanically seal all edges, as moisture tends to penetrate most quickly there. UV protection is also essential, as the material can otherwise fade or become brittle.
Additionally, I suggest storing the furniture in a covered area whenever possible and covering it with a weatherproof tarp during extended periods of rain. This will significantly extend its lifespan.
Nofege
20 Jan 2023 09:11
To help you effectively, here is a brief guide on how to proceed:
1. Preparation: Remove all fittings and lightly sand the surface with fine sandpaper (grit 120-150) to slightly roughen the paint layer.
2. Cleaning: Thoroughly wipe off the dust to prevent any particles from affecting the new coating.
3. Priming: Apply a primer suitable for exterior wood, such as one based on acrylic or alkyd.
4. Sealing: Then use a clear, waterproof exterior varnish or wood oil with UV protection. You can also combine both, applying oil first, then varnish.
5. Don’t forget the edges: Especially the cut edges and backsides need special attention because the wood is particularly vulnerable there.
6. Let dry: Each coat requires enough drying time—at least 12 to 24 hours, preferably in warm, dry air.
Common mistakes include insufficient sanding or neglecting the edges. Regular maintenance is also important to detect cracks or flaking early.
If you want a simpler solution: there are special weather protection films that can be custom-fitted. However, these are not a long-term solution.
loken
20 Jan 2023 12:37
Nofege schrieb:
Typical mistakes are insufficient sanding or neglecting the edges.
Absolutely! Edges are crucial; otherwise, water soaks in like a sponge.
I would also recommend, if possible, placing the furniture on feet or small pads to prevent direct moisture from the floor. This gives the MALM a bit of extra protection and keeps the mood up even in bad weather! 😉
By the way, I’ve had good experience with marine varnish – it’s quite durable and adds a nice gloss. If you prefer a subtle look, just choose the matte version.
It’s great that you’re taking on this project; it really makes the balcony feel much more inviting!
lajudo
21 Jan 2023 08:55
Thoroughly sand the wood.
Treat all sides with a special exterior wood varnish.
Regularly inspect and perform touch-ups as needed.
Do not place directly on the ground.
SONLIS
21 Jan 2023 13:02
loken schrieb:
I have had good experiences with marine varnish – it is quite durable and gives a nice shine.
That’s a very good tip. Marine varnish is not only attractive but also highly resistant to moisture and UV radiation. Of course, you should definitely choose a matte or satin finish to avoid the typical plastic-like appearance.
In addition to the varnish, I recommend applying silicone or acrylic sealants to all joints, if structurally possible. This will further reduce water penetration.
One more tip: Even if you seal the surface, it’s best to cover the furniture during heavy rain or extreme weather conditions. No protective material is completely waterproof over time, especially for furniture with particle board surfaces.
