ᐅ What is the best way to clean Malm furniture to remove water stains?
Created on: 7 Apr 2020 09:17
dardan
Hello everyone, I recently noticed some unsightly water marks on my IKEA Malm furniture that appeared after placing glasses or cups on it. The surfaces look slightly spotted and dull, even though they are made of lacquered MDF. My question is: What is the best way to remove these water marks from Malm furniture without damaging the surface? Which cleaning products and methods do you recommend to help the furniture retain its original shine and protection? Thanks in advance for your tips!
RABLA
7 Apr 2020 14:10
Simply take window leather, apply furniture polish, and rub in circular motions. Then polish dry. A simple and proven method.
LuMarcel43
7 Apr 2020 15:01
I would like to point out critically that some furniture polishes can contain solvents and silicones, which may cause long-lasting, difficult-to-reverse damage or discoloration if you do not pay attention to their ingredients.
tolokau schrieb:
For tougher stains, there are special furniture polishes for high-gloss finishes, e.g., 'Poliboy High-Gloss Furniture Care'.
I can only recommend this if you test the product first on an inconspicuous spot and are familiar with the ingredient list.
Does anyone have specific experience with polish residues or problems after using such polishes on Malm furniture, which has a lacquered MDF carcass?
REOHEINRIC
7 Apr 2020 15:47
On painted MDF surfaces of the Malm series, a combination of heat and gentle rubbing often helps to remove water marks. Here is a proven method:
- Place a clean, dry cotton cloth over the water stains.
- Heat the cloth using an iron set to low (no steam) and hold it briefly on the spot (max. 5 seconds), moving the iron continuously to avoid overheating.
- The heat helps to draw moisture out of the surface.
- Afterwards, treat the area with furniture polish.
Caution: This method should only be used on painted furniture, not on veneer or solid wood, as it may cause damage.
Joshbe
7 Apr 2020 17:24
I confirm REOHEINRIC’s advice: The combination of gentle heat and care products is often the only way to remove water rings from painted surfaces without excessive sanding or damaging the surface.
Additionally, I recommend applying a sealant with a special paint care product or wax after cleaning to protect the surface and prevent the stains from returning.
bupar
8 Apr 2020 08:15
I have had good experiences with similar cases involving Malm furniture using a special acrylic-based furniture care spray, which is applied sparingly and then gently polished.
For more severe water damage, a fine polishing agent can also help, but only on matte areas and following the instructions carefully. It is also important to always follow the manufacturer's guidelines, as MDF finishes can have different coatings.
To prevent water rings, I recommend using coasters.
dardan
8 Apr 2020 09:38
Thanks to everyone for the many tips and cautious advice! In summary, I have gathered the following insights:
- Start with mild cleaning and gentle cloths
- For visible water rings, suitable furniture polishes (e.g., high-gloss polish) can often help, but always test first in an inconspicuous area
- Heat (e.g., with an iron) can help to remove moisture, but use very carefully
- Avoid abrasive cleaners or aggressive cleaning agents at all costs
- Sealing/care after removing rust stains improves protection
Do you have any recommendations on how often furniture should be resealed or treated after cleaning? Is once a year sufficient, or should it be more frequent?
