I am planning to set up our Ikea Metod kitchen cabinets in an area accessible to children. My question is: how can I arrange the Metod cabinets in a safe and child-friendly way so that our little ones cannot reach dangerous or fragile items, but can still independently access things suitable for them? I would appreciate tips on organizing the interior, securing the cabinets to prevent tipping, and dealing with sharp edges or materials that may not yet be childproof. Maybe someone has experience with child-safe modifications or suitable accessories that work well with the Metod units?
I look forward to your suggestions and advice.
For childproofing Ikea Metod cabinets, I recommend the following measures:
- Use child safety devices such as latches or magnetic locks on cabinet doors to prevent access to hazardous contents.
- Install furniture anchoring systems to prevent cabinets from tipping over.
- Use lower cabinet shelves for child-friendly toys or items that can be freely accessible.
- To minimize sharp edges, soft edge profiles made of plastic are available, which are easy to install.
- Ensure clear organization within the cabinets so that nothing is accidentally within children’s reach.
- Optional: Replace shelves with plexiglass-like or shatterproof alternatives if necessary.
These recommendations are based on common safety standards for furniture accessible to children.
Hello Sinnau54,
To make the Ikea Metod cabinets truly child-friendly, it is important to consider the overall usage situation. Here is a detailed suggestion:
- Cabinet mounting: The Metod units are relatively stable but tend to tip over if not installed properly. Therefore, be sure to use sturdy wall anchors as per the instructions. This is essential when children are around. There are also special metal brackets available that provide extra stability.
- Door and drawer locks: Magnetic or mechanical child safety locks designed specifically for Ikea, for example the "Lurvig" system, can be used. These can be disabled when adults need access.
- Interior fittings: Use removable boxes or organizers in the lower compartments. This way, children can independently manage “open” areas that are safe for them.
- Edges and impact points: Besides common edge protectors, there are versions with foam padding that can be applied inside and outside if children play directly on them.
- Material considerations: Metod is basically melamine-coated, which is safe. However, I recommend checking the cabinets regularly for damaged edges.
Do you have a small sketch or photo of the planned installation location? Then I could suggest more specific ideas.
TEBILO schrieb:
Do you have a small sketch or photo of the planned installation location? Then I could suggest more specific ideas.Thank you for the detailed response! Unfortunately, I can’t provide sketches, but the area is an open breakfast nook that is separated from the kitchen—so it’s not a room with steep stairs or anything like that. The children can access the Metod modules from the front and partly from the side. Some of the cabinets are freestanding, while others are placed against the wall. The lower units are mainly intended for storage that is accessible to the children, while the upper units are primarily for storing items that the children don’t need to reach.
Are there differences in safety when it comes to the arrangement of the modules or the types of door mechanisms? For example, Ikea often has doors with soft-close and others without—could that make a difference?
Regarding door mechanisms: Soft-close doors are indeed beneficial because they prevent slamming, thereby reducing the risk of finger injuries, especially for children.
As for the arrangement of the modules: Lower cabinets are more accessible to children, so only safe or childproof items should be stored there. Higher-mounted units offer the opportunity to securely store important or hazardous items out of children's reach.
The combination of open and closed compartments can also be designed considering accessibility, for example, open boxes in the lower sections for toys or dishes.
Sinnau54 schrieb:
Are there differences in the arrangement of the modules or the type of door mechanisms in terms of safety?
