Hello everyone, I am looking for effective ways to make my IKEA Billy bookcases childproof. Specifically, my small children play near the shelves and sometimes take things out, but I want to prevent them from getting injured or the shelves from tipping over.
I have already considered securing the bookcases to the wall, but what other safety measures make sense? Are angle brackets and child safety locks on the doors or drawers sufficient? Are there any specific products you would recommend, or perhaps proven DIY solutions?
I look forward to tips on how to improve stability while keeping the shelves accessible and safe for the children. Thanks in advance!
Interesting starting point. In my opinion, solely relying on fastening to the wall is insufficient when small children are involved.
I don’t think so. Why not completely avoid open shelving and choose something else? Billy shelves are classic but not particularly child-friendly—mainly due to their often low stability.
If you insist on using them, try applying non-slip rubber pads under the shelves in addition to the usual wall anchors, and reinforce all shelves with metal brackets. Child safety locks or magnetic catches on the doors help keep little fingers away.
Also, pay attention to sharp edges, perhaps using edge protectors made of foam or silicone. This is often underestimated.
deojorg schrieb:
Are angle brackets and child safety locks on doors or drawers enough?
I would like to add a simple step-by-step guide that I have successfully used to make Billy shelves childproof:
1. Wall attachment: Use the included corner brackets and additional heavy-duty wall anchors to securely fix the shelf to a solid wall.
2. Edge protection: Install corner guards designed specifically for furniture on all corners and edges – these are easy to fit and prevent injuries.
3. Securing shelves: Fasten the adjustable shelves with metal clips or screws so they cannot be easily pulled out or shifted.
4. Doors and drawers: Use magnetic child safety locks that make opening difficult for children but remain convenient for adults.
5. Base support: Non-slip pads under the shelf feet prevent slipping on smooth floors.
From my experience, this combination of measures provides the best balance between safety and usability.
warrenka5730 Jul 2024 09:27I completely understand how important your children’s safety is to you. I used to worry because my child climbed on the furniture a lot.
I often found open shelves less safe because children have more unrestricted access. On the other hand, it’s true that some closed options are better if they are stable. For me, a combination of wall mounting, corner protectors, and secure locks has worked best.
At the same time, I always made sure not to place heavy, unstable items on the upper shelves. That gives me peace of mind and keeps the children safer. Maybe this helps you?
GALEO4 schrieb:
Why not go fully for open shelves and choose something else?
Hello, I would like to add that it is also important to consider the weight distribution on the shelf.
This is really important to prevent the shelves from being pulled out, which children could use as climbing opportunities.
Additionally, I recommend not placing heavy items in the lower shelves—they can tip over more easily there and are also within children’s reach.
For extra safety, use anti-tip devices that are installed between the shelving unit and the wall to prevent it from falling over even under load.
When choosing edge protection materials, I recommend foam-type products that are easy to shape and stick without falling off.
If you want, I can also provide some sources for these.
Nabla64 schrieb:
Secure the shelves with metal clips or screws so they cannot be simply pulled out.
