ᐅ Which BILLY models are better suited for heavy bookshelves?
Created on: 21 Feb 2019 18:23
V
Vin66
Hello everyone, I am planning to get a Billy bookshelf from IKEA to store a large collection of heavy reference books, which together are quite heavy. I am wondering which Billy models are best suited to support this weight permanently without sagging or getting damaged.
I am aware that there are different versions, sizes, and materials of the classic Billy – from the common 80 cm (31.5 inches) wide shelves to the HS versions with glass or wooden doors, as well as narrower or taller models.
I am specifically interested in which designs are recommended for heavily loaded shelves, whether reinforcements are available, or if it would be better to consider other IKEA options.
Additionally, I would like to know what structural differences in terms of stability actually exist (e.g., material thickness, back panels, number and type of shelves, fastenings) and what I should pay attention to during assembly to ensure the bookshelf can hold the heavy books permanently without damage.
Who has experience or tips, especially with heavily loaded Billy bookshelves? Thank you in advance!
miAlessio
21 Feb 2019 21:11
Hello, to summarize:
1. Technically, there are no special "Billy models" designed for heavy loads, as the system is standardized. The key factors for load capacity are the width and the number of shelves.
2. The standard 80x28 cm (31.5x11 inches) shelving unit can support shelf loads of approximately 13-15 kg (29-33 lbs). For higher loads, two approaches are recommended:
a) Adding extra center supports or metal brackets under the shelves to prevent sagging
b) Using narrower shelves (e.g., 40x28 cm / 16x11 inches) placed side by side to distribute the load horizontally.
3. The back panel contributes little to overall stability but helps prevent tipping. Secure attachment to a fixed wall is essential.
4. BILLY versions with glass doors do not have significantly better load capacity; the doors do not considerably affect the shelves' strength. However, doors can slightly increase the unit’s resistance to deformation.
5. Assembly: install the shelves according to the instructions, avoid overloading, and regularly check for sagging.
If you respect the load limits and add center supports if needed, you can safely store your books in the BILLY unit.
bujufa
22 Feb 2019 07:54
In addition to the previous discussion, I would like to point out the following:
- The load-bearing capacity of the shelves is the limiting factor, not the side panels.
- The original back panel made of thin MDF provides little reinforcement; its main function is to stabilize against lateral twisting.
- To accommodate heavy books properly, it is advisable to distribute the weight across multiple shelves and use metal bracket supports.
Furthermore, there are alternative shelving systems with thicker boards and higher load capacity if the load is truly very heavy.
jelite
22 Feb 2019 08:27
I would like to provide a brief overview of how you can optimize your BILLY shelf for heavy books:
1. Load each shelf with a maximum of 13–15 kg (29–33 lbs), according to the manufacturer’s guidelines.
2. If your shelf is 80 cm (31.5 inches) wide, standard shelves may bend easily. Use metal support brackets underneath the shelves for additional reinforcement.
3. Alternatively, place narrower 40 cm (16 inches) shelves side by side to better distribute the load.
4. Make sure to properly mount the unit to the wall, as this is essential for overall stability.
5. Freestanding or wall-mounted? BILLY is primarily designed for wall mounting; freestanding units can be problematic under heavy loads.
6. Wooden doors can slightly stiffen the side panels, while glass doors look nice but do not provide stability benefits.
Summary: No version is inherently better for heavy loads — stability mainly depends on correct load distribution, added reinforcements, and secure mounting.
V
Vin66
22 Feb 2019 09:01
edisondan schrieb:
According to the manufacturer, the maximum load per shelf is recommended to be 15 kg (33 lbs)
This is very important information for me, thanks. I have a number of technical books that often weigh more than 20 kg (44 lbs) per shelf. I will seriously look into reinforcement options.
mopra42 schrieb:
BILLY 80x28 is more stable than 40x28 due to the wider base
That sounds reasonable, but to keep the load lower, I could actually use several 40 cm (16 inches) wide shelves. That would probably distribute the weight of these heavy books better, right?
How exactly do you make these metal reinforcements? Are there specific recommendations or components offered by IKEA? Or only DIY methods?
Looking forward to more tips.
JOHNATHAN
22 Feb 2019 09:35
Vin66 schrieb:
How exactly do you make these metal reinforcements? Are there specific recommendations or components that IKEA offers? Or only DIY methods?
That’s quite a topic on its own 🙂 IKEA doesn’t officially offer specific metal reinforcements for BILLY, at least not officially. So most people improvise with simple metal brackets from the hardware store or screw thin aluminum plates underneath.
You can also buy so-called "shelf supports," metal brackets that you attach under the shelf to prevent the wooden board from bending. It takes a bit of DIY skill, but with a few screws it’s quickly done.
Otherwise, pay attention to wall mounting – a shelf that is properly anchored to the wall is much more stable, and the shelves don’t have to carry as much weight.
putan
22 Feb 2019 10:12
JOHNATHAN schrieb:
A shelf that fits well against the wall appears much more stable
And don’t forget: Sometimes just a little less weight on each shelf is enough to preserve the shelf. 🙂
I would definitely take advantage of the option to buy several shelves side by side and arrange the books according to their weight. If you ever move the shelf around, just place the heavy books on the bottom, and this will also reduce the risk of tipping.
