ᐅ Which BILLY models are better suited for heavy bookshelves?
Created on: 21 Feb 2019 18:23
V
Vin66
Hello everyone, I am planning to get a Billy bookshelf from IKEA to store a large collection of heavy reference books, which together are quite heavy. I am wondering which Billy models are best suited to support this weight permanently without sagging or getting damaged.
I am aware that there are different versions, sizes, and materials of the classic Billy – from the common 80 cm (31.5 inches) wide shelves to the HS versions with glass or wooden doors, as well as narrower or taller models.
I am specifically interested in which designs are recommended for heavily loaded shelves, whether reinforcements are available, or if it would be better to consider other IKEA options.
Additionally, I would like to know what structural differences in terms of stability actually exist (e.g., material thickness, back panels, number and type of shelves, fastenings) and what I should pay attention to during assembly to ensure the bookshelf can hold the heavy books permanently without damage.
Who has experience or tips, especially with heavily loaded Billy bookshelves? Thank you in advance!
miAlessio
22 Feb 2019 11:08
Brief summary of the construction for heavy books in BILLY:
- Where the maximum load per shelf is exceeded, an additional central support is advisable – metal brackets or even a central post work best for this.
- For tall shelving units, always use full wall anchoring to prevent shear forces and tipping.
- Secure the back panel additionally with wood screws; loose back panels reduce stability.
- Avoid fully loading a single shelf.
- If you buy multiple units, connect them with cam connectors (as offered for BILLY). This creates a stable interconnected system.
This way, you can significantly increase the durability when storing heavily loaded books.
V
Vin66
22 Feb 2019 12:15
Thank you for all the great tips so far. Here is a summary of what I have learned:
- Maximum load of 15 kg (33 lbs) per shelf for the standard BILLY
- Use of metal brackets or center supports for reinforcement is possible
- Using narrower shelves to better distribute the load
- Proper wall fixing is essential
- Doors do not significantly affect load capacity
Can anyone tell me if the newer BILLY models (from 2018 onward) use different or more stable materials than older versions? There are conflicting opinions in some forums about whether the material thickness has changed.
I am specifically looking for a model that I can use well for my project without having to install full DIY reinforcements right away.
bujufa
22 Feb 2019 13:02
Vin66 schrieb:
whether the newer BILLY models (from 2018 onwards) use different or more stable materials
As far as I am aware, IKEA has not made significant changes to the material thickness or construction of the BILLY shelves. The shelves still mainly consist of particleboard with a melamine foil surface, with back panels made of MDF or thin particleboard.
There is no official information indicating an increase in load-bearing capacity for newer models. Improvements in stability are usually related to accessories or fastenings rather than the material itself.
V
Vin66
23 Feb 2019 15:47
Since this topic involves many aspects, I would like to summarize the solution I have arrived at based on the discussion:
- I will combine several narrower BILLY shelves (40 x 28 cm (16 x 11 inches) width) to better distribute the weight.
- For the heavy shelves, metal brackets will be screwed under the shelves to prevent sagging.
- The shelves will be securely fixed to the wall and connected to each other.
- Doors will not be needed, as they do not provide any stability advantage.
- The weight of the technical books will be distributed as evenly as possible and kept below 15 kg (33 lbs) per shelf.
Many thanks to all participants who shared their knowledge and helped me make this decision!
