ᐅ How can I install the lighting for an Ikea Pax wardrobe myself?
Created on: 22 Apr 2016 17:23
islakiHello everyone, I am planning to install lighting inside my Ikea Pax wardrobe myself. However, I am still unsure about the best approach, especially regarding the power supply and the mounting of the light fixtures. What options are available, particularly for simple retrofit solutions that do not significantly affect the appearance? Do I need special tools or accessories, and are there any important considerations for the wiring, such as the type of current or safety? I would appreciate any tips on the best LED lights, switch options, or installation methods.
Johnathon22 Apr 2016 18:45Hello islaki,
if you want to install the wardrobe lighting for an Ikea Pax yourself, you should carefully consider a few technical details beforehand. It is recommended to use LED strips or small LED spotlights – these are energy-efficient and produce very little heat, which is important for a closed wardrobe.
For installation, you can use flat strips with self-adhesive backing or mount small spotlights under the shelves. For power supply, you have several options:
- 12V low voltage using a plug-in power supply, but in this case, you will need a cable channel on the wardrobe or have to route the cables precisely
- 230V direct connection, only if you are familiar with electrical installation or involve a professional
An important topic is the wiring: Make sure all connections are well insulated and that the cable cross-section is suitable. You can also buy wardrobe lighting with remote control or motion sensors if you want to simplify operation.
My advice: Measure the wardrobe accurately and consider how to hide the cables before buying the lighting. And always keep safety in mind, especially when dealing with mains voltage.
Do you already have an idea whether you want to connect the lighting yourself or prefer plug-and-play solutions?
The simplest solution is an LED strip with a USB plug and power supply. You can just place it inside and connect it to a power outlet. No drilling, no wiring.
Alternatively, there are self-adhesive LED strips, usually operating at 12V. In that case, you only need a basic plug-in power adapter. Attach the strip to the shelves or frames, secure the cables with cable ties, and you’re done.
Regarding Ikea Pax wardrobe lighting, the following electrical considerations should be kept in mind:
- Avoiding mains voltage inside the wardrobe (230V) in favor of low-voltage systems (12V or 24V) to ensure electrical safety.
- Using LED lights, as they emit little heat and are ideal for wardrobe use.
- Power supply with a compatible driver designed for the total wattage of the installed LED lights.
- Wiring should be as discreet as possible, using thin cables that are easy to route.
- Ensuring sufficient strain relief on the cables to prevent damage.
For installation, I recommend self-adhesive LED strips that can be connected with a plug connector (e.g., RJ45 or a 2-pin connector). This allows for a modular setup.
Are there power outlets near your wardrobe? This greatly affects the complexity of the installation.
Hello islaki,
I would like to offer you a step-by-step guide on how to install lighting in the Ikea Pax wardrobe yourself:
- 1. Planning: Decide which areas of the wardrobe you want to illuminate – for example, each shelf or just the sides.
- 2. Selection of light sources: LED strips are ideal because they are slim and generate little heat. Make sure they operate on low voltage (12V).
- 3. Power supply: It is best to use an LED power supply that converts 230V to 12V. Keep this in an external area (for example, behind the wardrobe).
- 4. Cable routing: Lay the cables as flush as possible along the shelves, using cable clips or double-sided tape to avoid loose wires.
- 5. Connection: Connect the LED strips to the power supply using suitable connectors. Pay attention to polarity—positive to positive, negative to negative.
- 6. Switch: If you want a switch, install it between the power supply and the lighting so you can turn the lights on and off.
- 7. Safety: Use only tested materials, preferably with CE marking, and avoid exposed contacts.
Tip: At first, you can mount all cables temporarily and test before securing everything permanently. This way, you can still make adjustments.
If you like, I can also provide sample product recommendations.
