ᐅ How can I easily disassemble Ikea Metod kitchen cabinets for a move?
Created on: 15 Mar 2021 18:37
FABA58
FABA58
15 Mar 2021 18:37
Hello everyone, I am planning a move in the next few weeks and have several Ikea Metod kitchen cabinets that I want to disassemble professionally and as simply as possible. I especially want to make sure to minimize any damage to the cabinets and fittings so they can be easily reassembled after the move.
Specifically, I am wondering: What are the most effective steps for disassembling the Metod cabinets, which tools should be used, and are there any practical tips or tricks to remove the parts without breaking them?
I look forward to your experiences and advice, as this is not my first time taking down these cabinets, but I have always been a bit hesitant due to the complexity and often delicate components.
tolokau
15 Mar 2021 19:02
Hello FABA58,
Your concern can be approached in a well-organized way. Here is a brief guide for dismantling Ikea Metod cabinets:
- Preparation: First, completely remove all cabinet doors and drawers. This makes handling easier and reduces the risk of injury. The fittings are often attached with Allen screws, so have a suitable Allen key ready.
- Loosening screws: For the Metod components, you mainly need a Phillips screwdriver and an Allen screwdriver. It is important not to fully unscrew the screws before the element is securely supported. This helps prevent warping or damage to connection points.
- Special considerations: The stability of the cabinets largely depends on the back panel. If the back panel is directly stapled or nailed, carefully and evenly pry it off using a flat lever tool to avoid damaging the boards and battens.
- Don’t forget numbering: Before dismantling, mark all parts with a marker or stickers. This makes reassembly much easier.
- Summary:
- Unscrew doors/drawers
- Loosen screws step by step
- Carefully remove the back panel
- Label and pack parts
Common mistakes:
- Removing the back panel too quickly before all screws are loosened
- Bending screws or driving them in too deep, which can enlarge the holes
If you have any questions about individual steps, feel free to ask.
PRABAU
16 Mar 2021 07:14
Remove doors and drawers. Then loosen the screws on the carcasses. Carefully pry off the back panel. Don’t forget the screws at the bottom and at the top.
PAR63
16 Mar 2021 09:26
I would like to add an important note on tool selection and handling to tolokau’s helpful guide:
- It is recommended to use a cordless screwdriver with adjustable torque settings to prevent screws from stripping.
- Initially, slightly loosen all screws before fully removing them to avoid parts suddenly falling apart.
- When removing the back panel, check whether it is particleboard or a thin MDF board – applying too much force can easily cause cracks.
For packing:
- Put hinges and small fittings into freezer bags and label them.
- Using a sorting box is worthwhile to prevent losses during reassembly.
These tips make the later assembly much easier and reduce stress during the move.
roryvin
17 Mar 2021 11:05
tolokau schrieb:
The stability of the cabinets largely depends on the back panel. If the back panel is directly stapled or nailed, carefully and evenly pry it off using a flat leverage tool to avoid damaging the boards and strips.
It is important to add that with Metod cabinets, the back panel is often only fastened with staples. If you rush here, you can tear it off and ruin the stability of the side panels when reassembling.
Also, you should not fully remove the screws from the hinges, but only loosen them enough to remove the doors. This way, the position is preserved precisely for reattaching later.
For transport, it is recommended to wrap the cabinets in a blanket or stretch film to protect the surfaces from damage.
