ᐅ How can I easily disassemble Ikea Metod cabinets for moving?
Created on: 28 Dec 2023 16:07
Lafipau
Lafipau
28 Dec 2023 16:07
I am planning to move soon and have several IKEA Metod kitchen cabinets that I want to disassemble as flexibly and carefully as possible to enable easy transport and reassembly during the move. My main questions are:
- What is the best way to dismantle the Metod cabinets without compromising the stability of the parts?
- Are there any special tips or tools recommended for easily taking apart the cabinet components, especially the connectors and the back panel?
- How should I ideally pack the individual components to prevent scratches and damage during transport?
If anyone has firsthand experience, it would be very helpful for my move. Thanks in advance for any constructive advice!
geralu
28 Dec 2023 16:19
To dismantle, first unscrew the doors and fronts. Carefully remove the back panel, which is usually only nailed. Loosen the connector screws, preferably with a cordless drill. Number the parts to keep track during reassembly.
Maria35
28 Dec 2023 17:45
I would like to add to the helpful advice from @geralu with a structured approach for the most flexible and secure transport of IKEA Metod cabinets:
- As already mentioned, first remove doors, drawers, and fronts to prevent damage.
- Then detach the back panel, which on Metod is often only fixed with small nails – be careful here to avoid damaging the wood.
- Remove the connecting fittings (Minifix and Lockdowels) using an appropriate Allen key or cordless drill.
- I recommend clearly labeling each part or marking them with tape and notes during disassembly. This greatly simplifies reassembly.
- For transport, heavy parts like the carcasses should be kept upright and protected with cushioning material to avoid stacking and unnecessary strain.
- Wrap cabinets and doors in blankets or bubble wrap to prevent scratches.
Additionally: When rebuilding, make sure all screws and fittings are well stored, ideally in a sealed container. This significantly reduces effort.
benon
29 Dec 2023 08:32
Hello Lafipau,
I hope my tip isn’t too late, but based on my experience, it’s important to approach moving your IKEA Metod cabinets with patience and a systematic method:
- Take photos of the entire kitchen before dismantling. This gives you a good visual reference for reassembly.
- Collect each screw or dowel separately in small bags and attach or label them directly to the corresponding boards.
- Be especially careful when removing the back panel, as it often provides structural stability. Sometimes it’s best to only remove loosely attached back panels and gently loosen those that are nailed in place.
- I recommend using a cordless drill with torque control to prevent damage.
Another tip: if you want to stay flexible, you can leave some modules partially assembled and only disconnect the connecting points, depending on the type of move. This saves assembly time on site.
Best regards and good luck with the move!
tutan
29 Dec 2023 19:11
benon schrieb:
If you want to stay especially flexible, you can also leave individual modules partially assembled and only disconnect the joints – depending on the type of move.
I can only agree with that! You don’t always have to take everything completely apart. Especially with Metod, many components are modular and the carcasses are sturdy enough to transport whole – as long as you secure and cushion them properly.
A little preparation is all it takes to make the move much easier. And honestly, who wants to spend hours looking for screws afterward? Numbering and packing them is half the battle.
If you’re interested, I can share a little trick on how to remove the back panels “almost” undamaged without breaking too many nails. Just let me know!
