ᐅ How can I cut and customize IKEA PAX shelving units myself?
Created on: 6 Feb 2021 09:22
philippe1
philippe1
6 Feb 2021 09:22
I am planning to cut and customize IKEA Pax wardrobes myself to fit a room with a non-standard height. I am especially interested in the best methods for trimming the side panels and back panels without compromising stability or significantly affecting the appearance. Are there any specific techniques or tools that have proven effective for this? Also, how should one handle adjusting the shelves when changing the height individually? I am looking for experiences and as detailed advice as possible on how to proceed so that the wardrobe remains just as stable and functional after modification as the original. Thank you in advance for your support!
Lorukeo
6 Feb 2021 10:37
When modifying and shortening IKEA Pax wardrobes, it is essential to use the right tools and follow the correct procedures. The side panels are usually cut with a fine-toothed saw or a miter saw for precise cuts. It is important to mark all drill holes and fastening points before cutting to avoid damage.
Stability can be maintained by adjusting or retaining the top and bottom crossbars, as they support the frame structure. Additionally, when shortening the back panel, it is recommended to carefully score along a straight line with a utility knife instead of sawing to prevent fraying.
For adjustable shelves, it is advisable to create new rows of holes inside the frame to customize the shelf height. Metal brackets or special connectors for carcasses enhance load-bearing capacity. For a neat finish, applying a suitable edge banding film is recommended. Overall, careful measuring and cutting are crucial to achieve a stable and functional result.
SUPE2
6 Feb 2021 11:05
Cut side panels with a fine-toothed saw.
Score the back panel instead of sawing to prevent fraying.
Adjust shelves by drilling new holes for the pins.
Keep the cross braces at the top and bottom for stability.
Secure edges with edge banding.
daalessio
7 Feb 2021 07:18
philippe1 schrieb:
I am planning to cut IKEA Pax wardrobes to specific dimensions and customize them to fit into a room with a non-standard ceiling height.
This is the key point – adapting to non-standard room heights. It is important to first create a detailed measurement plan before making the first cut. I recommend reinforcing and gluing the side panels with sufficiently strong wood glue after trimming, in case some stability is lost due to the modification.
Has anyone worked with thinner back panels before? My advice: it’s better to replace the original cardboard back panel with a thin plywood sheet if you want to significantly increase stability. This is especially useful if the wardrobes need to support heavier loads.
Regarding the shelves: drilling new holes on the sides requires precise drill jigs or templates to maintain even spacing. Otherwise, the shelf pins won’t fit properly or may be crooked. Here, too, a step-by-step approach with trial assemblies is advisable before fixing everything permanently.
ladali
8 Feb 2021 14:44
Lorukeo schrieb:
Stability can be maintained by adjusting or keeping the lower and upper cross braces, as these support the frame structure.
I agree with this. Additionally, when shortening the side panels, I would recommend checking whether the cabinet components are joined with metal connectors or wooden fasteners. In the latter case, stability depends almost entirely on proper gluing.
It is also important to carefully sand and seal the cut edges, especially if they are made of particleboard, to prevent moisture damage. The back panels can be cut to size with a circular saw or a fine-toothed saw; to minimize the risk of chipping, apply painter’s tape along the cut line before sawing.
For maximum flexibility, one might even consider breaking the shelf into smaller modular sections that can be adjusted individually. Assembly with brackets and support feet then provides stability. This avoids large, unstable side panels that are difficult to handle.
