ᐅ How can I customize Ikea PAX to meet my specific needs?
Created on: 28 Mar 2016 08:17
AHMAD52
AHMAD52
28 Mar 2016 08:17
Hello everyone, I am planning to get an Ikea PAX wardrobe system but have some specific requirements I would like to integrate. Specifically, I am looking for ways to customize the PAX so that it can be used with different interior configurations for clothing and technical equipment, possibly including special mounts for accessories. I am also interested in modifications related to accessibility, as I want to be able to operate the wardrobe with limited hand mobility. Are there any experienced users who have modified their PAX accordingly or who can offer practical advice on implementation? I would appreciate concrete suggestions or example setups to help find a tailored solution for my needs.
FABIAN_DEO
28 Mar 2016 09:23
AHMAD52 schrieb:
I am planning to get an Ikea PAX wardrobe system but have some specific requirements that I would like to incorporate.
Your question is very clearly defined, which makes giving recommendations much easier. There are indeed several ways to customize the PAX system, though some options might not be immediately obvious:
- Interior layout: You can combine Ikea’s standard and interior fittings with third-party components or custom-made shelf inserts. For example, pull-out drawer modules with special inserts for electronics are useful for organizing cables and devices.
- Special mounts: It can be helpful to install aluminum profiles or perforated panels on the back or side walls to attach accessories flexibly. The standard PAX back panels can be modified with some effort.
- Accessibility: For limited hand mobility, I recommend automatic door openers or electronic door closers, possibly combined with larger handles or multi-grip rails. Motion-activated lighting can also make the wardrobe easier to use.
Could you please describe in more detail which technical devices you want to store and what specific limitations you have? Then I can suggest more precise modifications or accessories.
Lisele
28 Mar 2016 11:04
Hello AHMAD52, I think your approach to customizing the PAX as individually as possible sounds very well thought out and reasonable. Especially with special needs, it’s important to focus on flexible solutions.
Some time ago, I also tried to adapt my PAX to changing requirements and found that it often comes down to details. It really helps to be patient with trial and error and to experiment with small parts like handles or DIY inserts.
What I also found helpful was not only thinking about the interior layout but also the accessibility of doors and drawers. Sometimes simple changes to the handles can make a big difference. I encourage you to keep at it – there are surprisingly many solutions you can achieve with a bit of creativity.
GIBAPO
28 Mar 2016 13:37
AHMAD52 schrieb:
possibly also with special brackets for accessories
Installing special brackets inside a PAX closet requires reinforcing or modifying the back panel or side panels accordingly. The back panels of PAX units are quite thin, so I recommend installing additional mounting plates or wooden battens behind the panel.
For organizing the interior space, using adjustable insert systems is helpful. IKEA offers some modular solutions, but accessory manufacturers for PAX are also a reliable source.
Regarding accessibility: due to the design of PAX doors, installing sliding doors can be preferable to hinged doors. Sliding doors require less movement to open, which is beneficial for limited hand mobility. Alternatively, cable or sensor-operated systems are possible but more complex and not standard options.
Overall, I suggest first evaluating how to best adapt the door mechanism to your individual needs, as this is usually the main limiting factor.
lechen
28 Mar 2016 14:02
Sliding doors instead of hinged doors take up less space and are easier to operate.
Replacing knobs with longer handles makes gripping easier.
Custom interior fittings or adjustable inserts allow for personal customization.
Clementbla
29 Mar 2016 10:15
FABIAN_DEO schrieb:
Could you please describe in more detail which technical devices you want to accommodate and what specific limitations apply?
This is important to suggest suitable solutions. For electronics, cable management systems in the PAX unit are essential to keep everything organized.
If mobility is limited, I would also recommend reinforced pull-outs or push-to-open mechanisms.
