ᐅ How can I customize the Brimnes from Ikea easily without much effort?
Created on: 1 Jul 2018 10:12
ginamo
ginamo
1 Jul 2018 10:12
Hello everyone, I’m looking for some input on the topic: “How can I customize the Brimnes furniture from Ikea in a simple way without much effort?” I’m searching for concrete ideas and possibilities that can be done with basic methods, so nothing involving complex modifications or major DIY projects. Maybe changes in color or materials, small add-ons, or practical tips that make the furniture more personal or functional. It’s important to me that these can be done relatively quickly and affordably. Does anyone have experience or tips on how to easily “upgrade” the Brimnes without requiring a lot of tools or special skills? I’m looking forward to your suggestions!
kla69
1 Jul 2018 11:25
Hello ginamo, your request is very clearly formulated, which I appreciate. There are quite a few ways to customize the Brimnes furniture piece individually and without much effort, which I would like to explain in more detail here:
1. Color design: A quick effect can be achieved, for example, by applying self-adhesive films or special furniture stickers. These come in many designs and also protect the surface. Make sure to choose the right thickness and quality so the film doesn’t shrink or develop bubbles after a short time.
2. Replacing handles: The Brimnes typically comes with simple handles. You can replace these with decorative handles made of wood, metal, or even retro-style plastic. It is important to measure the screw dimensions carefully; otherwise, you may need to drill new holes or modify the existing ones.
3. Interior optimization: Simply using baskets, boxes, or document holders from the Ikea range can make the interior more organized and personalized without altering the furniture itself.
4. Lighting: Clip-on lamps or battery-powered LED strips are relatively easy to install and can change the mood or functionality of the furniture piece.
My question: Which Brimnes piece are you using exactly (e.g., wardrobe, chest of drawers, TV stand), and how much freedom do you have regarding the surface? Do you already have experience with small renovation projects?
I’m happy to help if you provide more details!
mopra42
1 Jul 2018 13:07
Hello, I would recommend using simple wall stickers or decals. You can stick them onto the fronts and remove them later without leaving any residue. Alternatively, the handles can be quickly swapped out for others if needed.
LANICOLE
2 Jul 2018 08:34
Hello ginamo, I’d be happy to provide you with a simple step-by-step guide on how to customize your Brimnes with minimal effort:
- Step 1: Clean and prepare the surface. This is important to ensure paint or adhesive films stick well. A mild cleaner and a lint-free cloth are sufficient.
- Step 2: Choose your customization method. I recommend going for a high-quality contact film, as it is available in many designs.
- Step 3: Cut the film. Measure the area precisely and cut the film with a sharp pair of scissors or a utility knife.
- Step 4: Apply the film. Peel off the backing gradually and smooth the film with a squeegee or a card to avoid air bubbles.
- Step 5: Optional handle replacement. Unscrew the existing handles and replace them with new ones that match your style.
- Step 6: Optimize the interior. Add adjustable shelves or boxes to create accents and improve organization.
Tip: Be careful not to apply film on surfaces with rough textures, as this can make adhesion difficult.
If you like, I can also provide advice on color selection and where to source materials.
bijo54
2 Jul 2018 12:59
You can also use self-adhesive wood-effect film. It looks high-quality and is quick to apply. Changing the handles also gives a fresh look.
Rosaren
3 Jul 2018 09:16
In addition to the previous posts, I would like to point out that when using adhesive films on furniture with high-gloss surfaces or special wood coatings, compatibility should be tested beforehand. Sometimes, residue or even damage can occur after removal. Therefore, I recommend testing on an inconspicuous spot first and using high-quality films that can be removed without leaving any residue. Furthermore, handles made of metal or wood are a subtle yet very effective way to personalize the Brimnes quickly and with minimal effort, without negatively affecting the texture or surface quality.
