ᐅ Which types of screws are suitable for assembling the Ikea BRIMNES furniture?
Created on: 5 Jan 2022 08:22
Tar-peo
Hello everyone, I am currently facing the problem of looking for replacement screws or suitable screw sets for my Ikea Brimnes furniture set. It concerns the wardrobe with drawers, specifically the white version. I no longer have the original screws completely, or some are partially damaged, and I would now like to know which types of screws are actually compatible to fully ensure stability and functionality. Does anyone know the exact measurements, thread types, lengths, or screw heads that are suitable here? Are there universal set recommendations, or is it better to rely on specific Ikea original spare parts? I also want to avoid having loose or unsuitable screws that could make the furniture unstable. I would be very grateful for any help!
Palenar
6 Jan 2022 08:14
Good morning everyone,
Regarding the specific question about the types of screws used in Ikea Brimnes furniture, I can add the following: Ikea generally does not use any secret or proprietary screws. The system is based on standardized metric screws with common thread types and head shapes.
- It is important that the screw length is exact, as a screw that is too long can damage the furniture piece or affect its functionality.
- The head shape must also be correct: hex keys (Allen) are used for connector bolts, while Phillips heads are common for regular drawer and case screws.
- For screws used in metal-to-wood connections, such as drawer slides, flat head screws are standard.
I would recommend, if possible, measuring the length, diameter, and head type of all screws that need to be replaced using a simple caliper or ruler. Once you have these measurements, you can easily find replacement screws at hardware stores or from online spare parts suppliers. When in doubt, I would suggest opting for Ikea replacement parts, as they are perfectly matched to the furniture, including material quality.
If you provide a detailed list of the screws to be replaced along with their dimensions here, more specific screw sets can be recommended.
klo61
6 Jan 2022 10:05
Tar-peo schrieb:
Are there special types of screws that Ikea has used to prevent them from being replaced with regular screws?
I can clearly say no. Ikea uses standard screws to keep assembly as simple as possible for the average customer. Special screws or proprietary systems are quite rare.
So if you buy screws with the same dimensions (length, diameter, thread pitch) and the appropriate head type (Phillips for hand tools or Allen for connecting screws), they will fit perfectly.
A tip: Some screws are specially zinc-coated to prevent rusting indoors. Zinc-coated or stainless screws are therefore a good choice as replacements.
JAFUHAU
6 Jan 2022 11:53
I accidentally used regular wood screws on my BRIMNES furniture in places where connector screws with Allen heads should have been used. This quickly affected the stability negatively, and the screws often became loose.
So it's really best to replace the screws with the correct type; otherwise, the furniture will lose its sturdiness and cause frustration later on.
Sometimes it’s also worth not only considering the size but paying attention to how the screw grips the wood or metal – some have specially designed thread profiles.
Tar-peo
7 Jan 2022 09:17
Thank you all for the detailed and helpful contributions!
Here is a summary for myself:
- Side panels: M4x30 hex socket screws with wooden dowels
- Drawer slides: M3.5x16 flat head screws, Phillips
- Back panel: flat head screws 3x15 (presumably)
- Material: Galvanized steel is the standard, stainless steel optional
- Tools: Phillips (PH2) and 4 mm hex key needed
I will start by putting together a small replacement screw set using this information and will resort to original spare parts if needed. Thanks to the tips on material and tools, I have a clearer idea of what to look out for.
If anyone has precise screw lists from original manuals or from experience, please share!
Thanks again.
