I recently installed the METOD kitchen series drawers from IKEA and am generally quite satisfied with the quality and storage space. However, I find the fairly loud closing of the drawers quite annoying, especially when going into the kitchen early in the morning or late at night. My question is: How can I close METOD drawers quietly without compromising functionality or making complicated modifications?
It is important to me that there are solutions compatible with the original METOD components and that do not require extensive alterations. I am particularly interested in whether there are mechanical dampers, special drawer slides, or simple tricks to make closing smoother and quieter.
Who has experience with this or useful tips to prevent loud slamming without having to install additional foam or similar materials? Thanks in advance for your feedback.
V
valerie-tr14 Jun 2019 20:57Hello linake,
your question about a silent drawer from the METOD series is very valid, as the closing mechanism in many IKEA kitchen cabinets tends to be rather noisy.
First of all: METOD typically uses so-called ball-bearing slides or roller guides, which usually do not come with a soft-close mechanism as standard but simply lock mechanically. This explains the slamming noise.
Here is a systematic approach to prevent the drawers from slamming:
- Replace the existing slides with soft-close slides: IKEA sells compatible models that allow dampened closing. These are usually a bit more expensive but ensure significantly quieter operation.
- Retrofitting soft-close dampers: There are aftermarket small spring- or gas-damper-based modules that can be clamped or screwed onto the drawer sides. These reduce the closing speed and noise.
- Adjusting the drawer front: Sometimes drawers close louder if they are not perfectly aligned or mounted straight. Precise adjustment of the front and the runners can already reduce the slamming.
- Rubber buffers or silicone stoppers at the impact points: this reduces mechanical noise but is more of a makeshift solution.
What is important: If you decide to modify the drawers, check the measurements and installation dimensions of the slides very carefully to ensure compatibility. I myself switched the slides on a METOD kitchen run to IKEA soft-close models and was able to significantly reduce the operating noise.
One quick follow-up question: Are your drawers equipped with full-extension or half-extension slides? This can influence the choice of suitable dampers.
I’m looking forward to hearing what you decide!
neoJohnny15 Jun 2019 08:12Hello linake,
to answer your question as objectively as possible: METOD drawers usually do not come with soft-close as standard, which causes the annoying noise.
Practical solutions:
- Switch to IKEA soft-close drawer runners: These are easy to install and compatible.
- Retrofit soft-close adapters: There are third-party suppliers offering small mechanisms that can be attached to the existing runners.
- Be careful with custom modifications: Altering the sliding mechanism can affect its load capacity, so only use tested components.
Additionally, noise insulation can be improved by precise adjustment of all parts. The drawer should be installed so it moves smoothly and without play. This also prevents jamming and loud noises.
In general, the safest and most durable solution is to replace the system with soft-close runners if noise reduction is the main goal.
valerie-tr schrieb:
Retrofit installation of soft-close dampers: There are small add-on modules from third-party suppliers, based on spring or gas dampers, which can be clamped or screwed onto the drawer sides.This sounds generally interesting, but is the retrofit of dampers into existing METOD drawer systems technically feasible without issues? IKEA sometimes uses special mounting points and materials that don’t necessarily provide free installation surfaces.
I also wonder whether such add-on solutions are durable and mechanically reliable in the long term, or if they are more of a makeshift “DIY fix.”
One could argue that a complete replacement of the drawer slides is more involved but offers a well-thought-out and lasting solution. What do you think — is retrofitting with third-party components really a good alternative to replacement?
Or does anyone have solid practical experience with retrofit dampers specifically for METOD?
Jamalli schrieb:
What do you think – is retrofitting with third-party components really a good alternative to replacement?From my experience: yes, retrofitting can be a practical solution, especially when a full replacement is not desired or feasible.
- Retrofitted dampers are usually easy to install and do not require modifications to the drawer construction itself.
- It is important that the dampers are of high quality and precisely matched to the type of drawer slide.
- However, they generally only work with drawers that have roller slides or similar systems, not with classic ball-bearing slides.
Additionally, I recommend carefully checking the dimensions of the drawer slides before purchasing and, if possible, choosing a model designed for METOD or comparable IKEA systems.
So if the drawer is still stable and there are no mechanical problems, retrofitting is a good way to create a quiet kitchen without major intervention.
