ᐅ How can I better protect Malm furniture from water damage?
Created on: 5 Sep 2024 07:28
aranpin
aranpin
5 Sep 2024 07:28
I own some furniture from the Malm series by IKEA, and I would like to protect it better from water damage. Since this furniture is mainly made of particleboard with a surface coating, I am wondering what methods or tips are available to make it more resistant to moisture without compromising its appearance or functionality. Specifically, I am interested in whether there are special sealants, varnishes, or other care products suitable for protecting the furniture from splashes or minor flooding. Experiences with everyday use, for example in households with high humidity or use in damp rooms, would also be very helpful.
Thank you in advance for your tips and advice!
Kinbu
5 Sep 2024 08:47
Hello aranpin,
I understand that you want to protect Malm furniture from water damage as effectively as possible, since the combination of particleboard and finish is known to be sensitive to moisture.
In general, I recommend a clear, water-repellent sealant specifically designed for furniture. Look for products based on polyurethane or acrylic, and apply them in a thin, even layer on the surfaces. It is important to thoroughly clean and degrease the furniture before application to ensure the protective layer adheres well.
Additionally, it makes sense to protect particularly vulnerable areas (e.g., bases or floor sections near wet spots) with transparent protective films or by using special furniture feet to keep them off direct contact with the floor.
One more tip: regular reapplication—at least once a year depending on use—will maintain long-term protection.
If you like, I can also explain the application process in detail.
gasidney
5 Sep 2024 09:18
Hi,
use waterproof wood glue or water-resistant varnishes, preferably furniture-grade. For small splash protection, you can also use special protective pads or felt.
Domau0
6 Sep 2024 14:37
Kinbu schrieb:
Pay attention to products based on polyurethane or acrylic
This is an important point. Additionally, I recommend lightly sanding the Malm furniture before applying the sealant to make the surface more receptive to the protective layer. Use fine sandpaper, around grit 220.
For the protection to work effectively, it is crucial to apply the sealant carefully and evenly so that no pores or corners remain uncovered. It is better to apply several thin coats with drying time in between rather than one thick coat. Technically, a thick layer can alter the appearance and may peel.
One more thing: the piece of furniture should be placed in its final location and only exposed to damp environments after the sealant has fully cured – depending on the product, this usually takes 24 to 48 hours.
Are the furniture pieces located near faucets or in kitchens/bathrooms? Small details about the location help to recommend the appropriate protection.
aranpin
7 Sep 2024 10:02
Domau0 schrieb:
Are your furniture pieces located near water taps or in the kitchen/bathroom?
Thank you for your detailed answer! Yes, my Malm furniture is currently placed partly in the bedroom and partly in a room I use as a home office – there I sometimes have increased humidity because the window is not always open, and occasionally there is a pot of water next to it. They don’t actually get very wet, but I want to take preventive measures.
Since you mentioned it: do you think sanding makes sense if the furniture already has a protective finish? I’m a bit unsure if I might damage the original coating. Are there alternatives if sanding is too risky?
Also, I noticed that the surfaces are relatively smooth – that’s why I initially thought of using spray lacquer to apply it more evenly. From your experience, is that a good idea?
RENMA
7 Sep 2024 17:45
aranpin schrieb:
Do you think sanding makes sense if the furniture already has a protective coating?
Sanding an already painted surface is a common practice to improve the adhesion of a new layer. However, it should be done very lightly with fine sandpaper to avoid completely removing the old coating, only roughening the surface.
Alternatively, a special adhesion promoter can be used to prepare the surface without mechanical impact.
Regarding spray paint: Polyurethane-based spray paints are very suitable for achieving an even, thin layer. On smooth surfaces, they are often easier and cleaner to apply than roll or brush coatings. Good ventilation and working in a dust-free environment are important.
In conclusion: For Malm furniture, I recommend a combination of
1. light surface preparation (light sanding or adhesion promoter),
2. applying a suitable protective varnish,
3. additional protective measures at furniture edges or bases in case of moisture risks (e.g., waterproof sealing tapes).
This way, you achieve the best long-term protection.
